I was wondering if there is any command where I can Retrieve the Identification of the ERB I´m connected to. Is there any? AT ou ADL command?
Thanks a lot!
Henrique
rickonvb@yahoo.com.br
Thanks a lot!
Henrique
What’s an ERB?
Of course! ERB is in portuguese!
The term I would have to use is: MS or Mobile Station.
Is there anyway to get the MS identification?
Thanks!
Henrique
Hi Henrique,
I assume that by MS identification here, you means the IMEI number (which uniquely identifies an MS). To get that you can issue AT+CIMI command. This command can also be issued using adl_atCmdCreate () API.
Best Regards,
Open AT Fan.
Hi OpenAt! How are you?
I finally found out what I was looking for!
The command is CCED. I was needing the CELL Ids and their Signal Levels. They´ll be used to triangle tracking.
Thanks!
Henrique
