yarns
March 1, 2007, 7:51am
1
i want use IMEI to cryptography in communication via GPRS.
I know how can i get IMEI using AT commands, but how i can get it from my C++ code? Checked ADL manual and didnt find anything about IMEI. Is there a way to use AT in C++? If yes how i can make it?
Greetings
P.S.
Sorry for my lame question but i’m a newbie
jan
March 1, 2007, 8:22am
2
Hi yarns,
Try adl_atCmdCreate… This function lets you do any AT command from ADL. You’ll find something on how to use atCmdCreate in the ADL manual.
Best Regards,
Jan
awneil
March 1, 2007, 8:47am
3
Yes, you’ll have to use adl_atCmdCreate()
Then look-up the appropriate AT Command in the AT Commands Manual , and handle the response in your application
It would be really useful if Wavecome provided direct access to this kind of information without having to mess about with AT commands…
See: wavecom.com/modules/movie/sc … =4187#4187
yarns
March 17, 2007, 11:44am
4
Still have a problem with it
have in main:
adl_atCmdCreate("at+wimei?",
TRUE,
(adl_atRspHandler_t)WIMEI_Response_Handler);
and
s16 WIMEI_Response_Handler(adl_atResponse_t *paras)
TRACE (( 1, paras->StrData ));
in traces i got message “OK”… so where is imei?
Greetings
awneil
March 17, 2007, 1:09pm
5
I think you need to re-read the documentation for adl_atCmdCreate - hom many parameters should it take…?
yarns
March 17, 2007, 3:46pm
6
Can you be more cleary? When i gives :
TRUE,
(adl_atRspHandler_t)WIMEI_Response_Handler,NULL);
handler is not even called…
Greetings
should be :
TRUE,
(adl_atRspHandler_t)WIMEI_Response_Handler,"+WIMEI",NULL);
always Read The ******* Manual
yarns
March 17, 2007, 6:59pm
8
Yeah i know RTFM
But i checked it in ADL User Guide and didnt find it there… adl_atCmdCreate is described in 3.2.5.1, and there is nothing about additional parameter like “+WIMEI”… and by the way… still dont work
when using:
TRUE,
event is not called, so when using:
TRUE,
(adl_atRspHandler_t)WIMEI_Response_Handler,"+WIMEI");
event is called but getting only “OK”
I’m really confused…
Greatings
awneil
March 17, 2007, 11:06pm
9
Yes there is - read it again carefully.
And look at the example provided.
After the response handler, there is a list of responses to “subscribe” to, and the NULL terminates that list.
yarns
March 18, 2007, 5:39am
10
Maked some stupid logic error… wondering why cant get IMEI - its normal when trying code like :
else if (paras->RspID==ADL_STR_OK)
//Here send IMEI
Sorry for that…
Thank you all for yours help.
Greetings
