Rc7630 couldn't get IP address under ubunut Linux(RC7630)
I can run the MBPL connection manager application with RC7620:
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo ./bin/lite-qmi-connection-managerhostx86_64
lite-qmi-connection-manager v1.0.2211.0
Open transport "/dev/cdc-wdm0" on USB device in QMI mode
Interface id: 8
Device interface: RmNet
QMAP enabled
Model: RC7620
Device Power Status: 0 - Online
HomeNetwork: CMHK
Network Selection Preference: auto
SessionStatus (0:ipv4): Disconnected
SessionStatus (1:ipv6): Disconnected
SessionStatus (2:ipv4): Disconnected
SessionStatus (3:ipv6): Disconnected
SessionStatus (4:ipv4): Disconnected
SessionStatus (5:ipv6): Disconnected
SessionStatus (6:ipv4): Disconnected
SessionStatus (7:ipv6): Disconnected
Auto-ping check on connection: enabled
Routing table update on connection: enabled
Please select one of the following options or press 'q' to exit:
    1.	start a single-PDN data session
    2.	Start one connection of a multi-PDN data session
    3.	Stop one connection
    4.	Stop all active connections
    5.	Display all profiles on the device
    6.	Display one profile on the device
    7.	Create a profile on the device
    8.	Modify an existing profile on the device
    9.	Delete a profile from the device
    10.	Scan available networks
    11.	Lock PCI
    12.	Disable PCI locking
    13.	Get PCI locking
    14.	Enable QOS Event
    15.	Disable QOS Event
    16.	Request QOS Expanded
    17.	Get QOS Information
    18.	QOS Indication Register
    19.	Read QOS Data Statistics (SWIQOS)
    20.	Read QOS Extra APN Parameters (SWIQOS)
    21.	Get Packet Statistics
    22.	Get Current Channel Rate
    23.	Toggle pinging on connection
    24.	Toggle routing table update on connection
    27.	Enable QMAP
    28.	Disable QMAP
    29.	Enable/disable WDS event report indication
    30.	Enable/disable keep data session alive
    (q)uit to exit:
1
Please enter Network selection preference (0: Auto (default), 1: Manual) (up to 3 Characters), or press <Enter> to use default value:
Please enter Connect via 0: existing profile (default) or 1: explicit APN (up to 3 Characters), or press <Enter> to use default value:
ID PDPType IPAddress           PrimaryDNS          SecondaryDNS        Auth ProfileName         APNName             UserName
1  0       0.0.0.0             0.0.0.0             0.0.0.0             0                        CMHK
2  3       0.0.0.0             0.0.0.0             0.0.0.0             0                        ims
3  3       0.0.0.0             0.0.0.0             0.0.0.0             0                        sos
Please enter a profile id (1-42) (up to 4 Characters), or press <Enter> to exit: 1
1: IPV4 (default)
2: IPV6
3: IPV4V6
Please enter IP family preference for the call (up to 3 Characters), or press <Enter> to use default value:
WDS[0] BindMuxID 1 returns 0
WDS[0] setIPFamily preference 4 returns 0
Starting data session via profile 1
WDS[0] IPv4 data session started successfully for Profile ID: 1
<< receiving WDS_PKT_STATUS_IND
WDS IND: msgid 0x22, type:4
[unpack_wds_SLQSSetPacketSrvStatusCallback]
	Packet Service 0 Status: 0x2, Reconfig required: 0
	IP Family: 4
	Technology: 0x8004
	Bearer ID: 0x5
SessionStatus (0:ipv4): Connected
SetAdaptorMtu(qmimux0:4) mtu 1500
SetAdaptorMtu(wwan0:3) mtu 1500
Up adaptor wwan0(3)
Up adaptor qmimux0(4)
SetAdaptorAddress(family 2): ip addr add 10.99.157.195:29 dev qmimux0(4)
IsAdaptorUp - Adaptor wwan0 is up
IsAdaptorUp - Adaptor qmimux0 is up
SetRoute(family 2): route add 0.0.0.0:0 dev qmimux0(4) gw 0.0.0.0
PING 8.8.8.8 56 bytes data in ICMP packets.
64 bytes from 8.8.8.8 icmp_seq=1 ttl=58 rtt=4001.000 ms
64 bytes from 8.8.8.8 icmp_seq=2 ttl=58 rtt=3001.000 ms
64 bytes from 8.8.8.8 icmp_seq=3 ttl=58 rtt=2000.000 ms
64 bytes from 8.8.8.8 icmp_seq=4 ttl=58 rtt=1000.000 ms
--------------------PING statistics-------------------
4 packets transmitted, 4 received , %0 lost
After that I can ping google server via qmimux0 interface:
owner@ubuntu:~$ ping 8.8.8.8 -I qmimux0
PING 8.8.8.8 (8.8.8.8) from 10.99.157.195 qmimux0: 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=58 time=133 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=58 time=17.2 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=58 time=24.0 ms
I can also start the network connection by qmicli in Ubuntu 18:
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo qmi-network /dev/cdc-wdm0 start
Loading profile at /etc/qmi-network.conf...
    APN: CMHK
    APN user: unset
    APN password: unset
    qmi-proxy: no
Checking data format with 'qmicli -d /dev/cdc-wdm0 --wda-get-data-format '...
Device link layer protocol retrieved: raw-ip
Getting expected data format with 'qmicli -d /dev/cdc-wdm0 --get-expected-data-format'...
Expected link layer protocol retrieved: 802-3
Updating kernel link layer protocol with 'qmicli -d /dev/cdc-wdm0 --set-expected-data-format=raw-ip'...
Kernel link layer protocol updated
Starting network with 'qmicli -d /dev/cdc-wdm0 --wds-start-network=apn='CMHK'  --client-no-release-cid '...
Saving state at /tmp/qmi-network-state-cdc-wdm0... (CID: 3)
Saving state at /tmp/qmi-network-state-cdc-wdm0... (PDH: 2248177728)
Network started successfully
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ ping 8.8.8.8 -I wwan0
connect: Network is unreachable
owner@ubuntu:~/QMI/MBPL/MBPL_SDK_R30_ENG6-lite.src/MBPL_SDK_R30_ENG6-lite.src/SampleApps/lite-qmi-connection-manager$ sudo udhcpc -i wwan0
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 10.98.52.161
udhcpc: lease of 10.98.52.161 obtained, lease time 7200
PING 8.8.8.8 (8.8.8.8) from 10.98.52.161 wwan0: 56(84) bytes of data.
64 bytes from 8.8.8.8: icmp_seq=1 ttl=117 time=99.4 ms
64 bytes from 8.8.8.8: icmp_seq=2 ttl=117 time=35.6 ms
64 bytes from 8.8.8.8: icmp_seq=3 ttl=117 time=29.6 ms
Lastly I have also followed the link below to establish data connection with AT!SCACT.
It is working fine on my Ubuntu 18:
