Hi Guys,
I want to execute the “AT+KSLEEP=2” command to disable sleep mode for UART1. UART1 sleep mode is disabled for the current session only. Although the “AT+KSLEEP=2” command does keep its state after a power cycle UART1 still falls asleep. Only repeated command “AT+KSLEEP=1” followed by “AT+KSLEEP=2” helps. But after the power cycle, the sleep mode turns on again. For comparison, I also have HL7692 - everything works correctly there.
Below is the report. Please advice. Thanks in advance!
AT+KSLEEP=2 //enter no sleep mode (regardless of DTR state)
AT+KSLEEP=2
OK //the command completed successfully
AT+KSLEEP? //status check
AT+KSLEEP?
+KSLEEP: 2 //the UART1 state saved correctly
AT!RESET //reboot
AT!RESET
+SIM: 1 //modem started
+KTCP_NOTIF: 1,5
AT //the commands are sent at intervals of more than 5 seconds - no response
AT //UART1 is sleeping
AT //
OK //UART1 wakes up after the command (<5sec)
AT+KSLEEP?
+KSLEEP: 2 //state saved correctly but UART1 is sleeping
AT+KSLEEP=1 // reset-set helps, but only in the current session
AT+KSLEEP=1
AT+KSLEEP=2
AT+KSLEEP=2
AT //the commands are sent at intervals of more than 5 seconds, the modem is responding
OK //UART1 is not sleeping
AT
AT
AT
AT!RESET //reboot
AT!RESET
OK //After reboot UART1 goes to sleep again
+KTCP_NOTIF: 1,5
AT
AT
ATI
Model: RC7620
Revision: SWI9X07H_00.08.07.00 0ce4c1 jenkins 2021/03/17 02:18:20
IMEI: 353634110241543
IMEI SV: 17
FSN: 7Q1385310310B0
+GCAP: +CGSM
The version 8.07 dates from March 17, 2021 and since no stable version corrects this problem !!
We are in January 2023. For a large manufacturer like SIERRA this is unacceptable. Do you have a release date for a next stable version ?
Yes, I have already contacted the distributor.
In June 2022 he wrote to me:
It seems that there is a bug on the R9 version at the update. It will be fixed in a version R9.0.1, I do not have yet the availability of this new version. In the meantime, I encourage you to suspend the update to R9
The R9 version corresponding to the link you sent me is still dated March 21, 2022. No R9.0.1 available.
So I ask you again: Do you have a release date for a next stable version ?
No, I use QMI for update.
Yes, I send to the modem AT+KSLEEP=1 then after AT+KSLEEP=2 so that it never goes into sleep mode.
this fixes the problem. But I’m having other problems especially when roaming and I was hoping to get a newer version of the modem.
No, I do not have a release note from the distributor.
