The write zyklus is ok (look at picture attached)
First 4 Lines are MOSI
1.Line Interpreter
2.Line Data
3.Line Clock
4.Line CS (go low 18us bevor image and high 10us after)
and the same for MISO
then, the CS goes high for 200us and low again to read-Zyklus -> Write Zyklus is OK
Read-Zyklus:
MOSI is alway 0
clock is toggling
CS is low
MISO has some Data (different from 0 or FF)
i think you mean move.
well. essentially there’s no difference between the Q2686 and the Q2687 except for the parallel bus.
so SPI operation is the same for both (including pin-layouts etc.)
if you trace the data right after you do the “adl_busRead” you get the same results?
also, are you sure the spi mode is right? (can’t tell the timings from your picture)
I do have SPI running, and i have had problems like you have, but my problems were always related to wrong spi-mode settings or bad connections.
so i’m a bit out of ideas right now.
hi fakulatus,
i am also working on same thing from last 4 days .i implemented spi communication but its not working properly…i am also studied basic example but its not useful for my application. my application is interfacing with sd card.
one thing i suggest after reading u r code configure the pins (25,24,22) by using io direction structure .i don’t think its not much necessary but my working working after making these modification .
If i subscribe the GPIO, i can’t subscribe the SPI (ADL_RET_ERR_BAD_HDL If a GPIO required by the provided bus configuration is currently subscribed by an Open AT® application)
I looked a hundred times for hardware-errors, but can’t find anyone
I’ve changed to the Wavecom-Demokit and have the same Problems, so it seams to me that can not be a HW-Problem.
Hi Dear all ,
we can exchange our ideas we can make good working code for SPI. Please share all your ideas we can give the final conclusion for this thread.First We Can clear these questions .
1.What are basic Steps need to implement SPI?
2.what are the basic steps while programming for wavecom module (Q2686)?
3.Is It necessary to use opcode and address in programming ?
if anyone don’t like it please leave this post…
tristate is just that the input is not driven by the module.
if no external source drives the line, then you will read noise. (which can mean that it reads 0xFF)
in my experience, continuous readings of 0x00 of 0xff, usually, point to bad connections somewhere.
but seeing that you problem seemed to be solved by re-uploading the firmware, it seems to me that some low-level setting got corrupted earlier on in the test cycle
Thanks for Your Response.Now i am interfacing q2686 with Sd Card through SPI communication.
i am implementing basic step For writting raw and reading raw data.That code works with AVR microcontroller working fine .I am using Same code using for Q2686 just read and write operation using q2686 Spi.
my problem is:
i am able to detect SD card (means SD Card intiliazation ) fine.
But for wrrting data and reading data its not working. its not giving any compiler errors or warrning…its reading garbage data…
i already i posted my code in this thread…
Thanks &Regards…
kiran.
