I’m trying to set up GPRS/3G connections using the AT commands, i can do this in a terminal and i start to get the PPP frames coming down when i run “ATD99 **1#”. I want to use PPPD, but i can’t seem to get it working. Does anyone have any known working PPPD configurations?
Thanks Liam
I have the same problem. Did you get the solution?
awneil
November 12, 2010, 7:31am
3
What have you actually tried?
What were the results?
lmgtfy.com?q=GPRS+PPPD
I tried to change the configuration of pppd in different ways, but the result is always the same:
Nov 11 10:48:11 ivtu3_v2_WIFI daemon.notice pppd[2287]: pppd 2.4.4 started by root, uid 0
Nov 11 10:48:33 ivtu3_v2_WIFI daemon.info pppd[2287]: Serial connection established.
Nov 11 10:48:33 ivtu3_v2_WIFI daemon.debug pppd[2287]: using channel 36
Nov 11 10:48:33 ivtu3_v2_WIFI daemon.info pppd[2287]: Using interface ppp0
Nov 11 10:48:33 ivtu3_v2_WIFI daemon.notice pppd[2287]: Connect: ppp0 <–> /dev/ttyPSC1
Nov 11 10:48:34 ivtu3_v2_WIFI daemon.warn pppd[2287]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Nov 11 10:48:34 ivtu3_v2_WIFI daemon.debug pppd[2287]: sent [LCP ConfReq id=0x1 <asyncmap 0x0> <magic 0xc5ba2b46> ]
Nov 11 10:48:34 ivtu3_v2_WIFI daemon.debug pppd[2287]: rcvd [LCP ConfAck id=0x1 <asyncmap 0x0> <magic 0xc5ba2b46> ]
Nov 11 10:48:36 ivtu3_v2_WIFI daemon.debug pppd[2287]: rcvd [LCP ConfReq id=0x1 <mru 1500> <asyncmap 0x0> <magic 0x2cc0c0ec> ]
Nov 11 10:48:36 ivtu3_v2_WIFI daemon.debug pppd[2287]: sent [LCP ConfAck id=0x1 <mru 1500> <asyncmap 0x0> <magic 0x2cc0c0ec> ]
Nov 11 10:48:36 ivtu3_v2_WIFI daemon.warn pppd[2287]: Warning - secret file /etc/ppp/pap-secrets has world and/or group access
Nov 11 10:48:36 ivtu3_v2_WIFI daemon.debug pppd[2287]: sent [PAP AuthReq id=0x1 user=“movistar” password=]
Nov 11 10:48:37 ivtu3_v2_WIFI daemon.debug pppd[2287]: rcvd [LCP TermReq id=0x2]
Nov 11 10:48:37 ivtu3_v2_WIFI daemon.info pppd[2287]: LCP terminated by peer
Nov 11 10:48:37 ivtu3_v2_WIFI daemon.debug pppd[2287]: sent [LCP TermAck id=0x2]
Nov 11 10:48:40 ivtu3_v2_WIFI daemon.notice pppd[2287]: Connection terminated.
Nov 11 10:48:40 ivtu3_v2_WIFI daemon.warn pppd[2287]: disconnect script failed
Nov 11 10:48:40 ivtu3_v2_WIFI daemon.notice pppd[2287]: Modem hangup
