Program via the USB
I am usinf the Q26 development board, on wich there is already a USB connector available. I understand it can be used the same way as the UARTS but is it also possible to download my program to the AirPrime module via this USB connector?
I have looked for the answer myself but haven’t found it yet
You can download a program via USB in the same way you download it using UARTS. But before using
the USB you will have to activate the USB feature using AT+WMFM=0,1,3 command.
Provided you have a suitably recent Firmware version!
Recent Firmware versions have USB enabled by deault.
