Hi, im trying the Simple Sample on my Fastrack Supreme 20, i´m using the M2M V1.0.2 and FW R74.
when i load the SimpleSample.dwl and start the application with at+wopen=1 i´ve recieved this messeges in the shell
GPS Sample: Application Started
GPS Sample: CGPS Feature not activated
I have read the documentation and threads in this forum but i could´n find How to Activate de CGPS with the new firmware release.
thanx for comments.
PD: i ´ve talked to my distributor and i didn´t receive any answer.
Thanks Awniel, i forgot to tell that i run this command and i´ve got this response
AT+WCFM=5
+WCFM=00000071,0
so, if i´m not misunderstanding the AT Command Interface Guide, i have enable:
01 Internet Plugin
10 Real Time Operating System
20 Open SIM Access
40 Open AT C-GPS Plug in
Am i right? because my distributor said that they never had this problem before, and they never had to enable any feature in the fastracks that he sells.
I was using the C-GPS a lot recently and have had quite a few problems with it, although I have been able to solve them with help from my distributor. The C-GPS can be quite complicated, but the use of the Simple Sample should work just fine. One thing I know is that it is Firmware and OS specific. If I remember correctly you project and hardware needs to be on OS 6.21 and firmware 7.3
Check your OS version and firmware of your harware and software.
Is this with OPUS-I or OPUS-III? I was working with OPUS-I
This is not unique to Open-AT - anytime you’re building any stuff that has to use other stuff pre-installed on the target, you must make sure that your build is compatible!
My module is a OPUS-I, my OS is 6.3 and the fw is r74_00gg.
I’m using the plugin Open AT C-GPS Plug-In v1.07 to compile the samples, because i don’t have the .dwf files. I compiled the SimpleSample that doesn’t need any command to start and the application returns the message:
Have you checked if the C-GPS Plugin is activated with AT+WCFM=5?
If it is activated change your firmware and OS. I was using C-GPS-OPUS-I Open AT Plug-in Package(1.7.0.20) and im quite sure that package only works with OS 6.21 and Firmware 7.3.
I am a very newbie and trying to get GPS information with Fastrack Supreme but I had no luck. I downloaded the SimpleSample application to the modem, but I got nothing after
AT+WOPEN=1
Following instructions in a manual, I enabled the active antenna power supply by using commands:
AT+WHCNF=0,0
AT+WIOM=1,”GPIO8”,1,0
AT+WIOW=”GPIO8”,0
The modem responded OK for each command, but I still did not get GPS information.
Moreover, I used SimpleSample and then QueryApp application, but did not get any luck. With SimpleSample application, responses for commands: AT+NMEA=1; AT+CGPS=2; and AT+CONFIG=1 are ERROR, but OK for QueryApp. Although the LED light was blinking, I got nothing.
