Configure module for ACTIVE mode with the GSM stack turn-off
AT+WBHV=1,1
Restart module
AT+CFUN=1
Turn on GSM stack without restart
AT+CFUN=1,0
AT+CSQ and other commands work fine for a few seconds, then
+WIND: 8
+WIND: 0
And GSM stack is turned off…
AT+CFUN?
+CFUN: 0
After that I have to run AT+CFUN=1,0 AGAIN in order for everything to start up properly…
Full example log:
AT+WBHV=1,1
AT+CFUN=1
+WIND: 3
+WIND: 13
AT+CFUN=1,0
AT+CFUN?
+CFUN: 1
+WIND: 7
AT+CSQ
+CSQ: 24,0
+WIND: 8
+WIND: 0
AT+CFUN?
+CFUN: 0
AT+CFUN=1,0
+WIND: 1
+WIND: 16
+WIND: 15,4,"13/08/07,14:16:29+08",6,"1"
+WIND: 7
+WIND: 4
+WIND: 10,"SM",0,"FD",0,"ON",0,"SN",0,"EN",0
+WIND: 11,,,,"505641C3BDDEDD3048674D0FCDA34382","19A48D9236D32DFF1E1A6BD2AD77CB17","E554E183848BAC9B7451CE3D126279DA"
Tested on Q2687RD and SL6087 with R7.46 and R7.52 firmwares.
Question is, why does the GSM stack not turn on reliably on the first AT+CFUN=1,0?
How can I be certain that I only need to run AT+CFUN=1,0, wait for +WIND: 8, then run AT+CFUN=1,0 again in order for the GSM stack to turn on properly?
Adding in a AT+WBHV=1,0 before turning on GSM stack with AT+CFUN=1,0 does not help…
I’m not certain I can go into the reasons for why I need to be able to start the module without GSM stack turned on, and then turn it on later.
