Problem to create a library
I tried to create a library using the project wizard from OpenAT 3.10. The project will be created but during wmmake I get the message
and the library won’t be create.
The complete output is
Is there any way to solve the problem
Best Regards
Ralf Ebert
You’ve probably added header files since the last successful compile.
The build system can for some reason not detect and get new header files when needed.
I just clean out the ads/out/ or gcc/out/ directories when that happens and start a clean compile.
Thank you for your help
Best regards
Ralf
