Expecting macro or rule defn, found neither
can anybody help me with this message?
“make.exe: …/…/Hello_World.mak: line 4: Error – Expecting macro or rule defn, found neither”
I am trying to build hello world sample project for target mode in visual C++.
could you share with us which version of OpenAT you are using?
Also, how does this line look like?
Best Regards,
Jan
thanks for your interest.
The version of openAT is 4.00.b04. The same project works fine in remote mode, but when I am trying to build it in target mode I get the following output at the build window:
--------------------Configuration: Hello_World - Win32 Wismo_Target--------
Software Generation Toolkit
SGT_VER = v1.2.11
SGT_DIR = /cygdrive/C/OpenAT/Tools/SGT/v1.2.11
Scripts path for SGT :
/cygdrive/C/OpenAT/Tools/SGT/v1.2.11/script_sgt
Type help_sgt for a list of SGT commands
/cygdrive/c/ct51
Check environment settings…
Launch a full library or binary process
Find errors occurred when using SGT
Analyze errors in Log files
Analyze errors in tmp files if they exists.
Libraries available in out directory :
End process.
Hello_World - 1 error(s), 0 warning(s)
If I try to compile only the “Hello_World.c” file I am getting a message that “no compile tool is accosiated with the file extension”
Any suggestions?
Best Regards,
Ioannis
Hi Ioannis,
It is quite normal, that you can’t build single files. Even if they would compile separately, you wouldn’t have a downloadable binary…
Unfortunatly, I haven’t worked with OpenAT 4 yet, so I didn’t come across this problem… Maybe somebody else here has?
Could you check for the file Hello_World.mak and tell us what is written in line 4? Maybe this helps to find out what the problem is…
Best Regards,
Jan
Hi Jan,
I have deleted the Hello_World.mak file but here is another mak file with the same problem:
Include this file only one time
ifndef MAKEFILE_INCLUDED
MAKEFILE_INCLUDED = YES
Library module (lib) or Binary module (bin)
PROCESS = bin
Set the used Api for Open-AT : ADL or OAT (standard Open-AT API)
API = ADL
Use the old task interface (ON/OFF)
USE_OLD_TASK_INTERFACE = {USE_OLD_TASK}
Set GCC Call Stack factor (to increase Call Stack size automatically for GCC compiler)
GCC_STACK_SIZE_FACTOR =
List of source files of the library or executable to generate
SRC_C_LIST =
appli.c \
List of assembler files of the library or executable to generate
SRC_ASM_LIST = \
List of objects real names to use for making binary file
EXTERNAL_OBJ_LIST = \
List of objects prefixed names to use for making binary file
PREFIXED_OBJ_LIST = \
List of libraries real names to use for making binary file
EXTERNAL_LIB_LIST = \
List of libraries prefixed names to use for making binary file
PREFIXED_LIB_LIST = \
Add-on used library list (as TCP/IP library, for example)
OTHER_LIB_LIST = \
Compilation flags
PP_OPT_COMMON =
OAT_API_VERSION=400 \
Path for code C files
PATH_C =
…/…/src \
Path for code ASM files
PATH_ASM = $(PATH_C)
Path for include C files
PATH_H =
…/…/inc
…/…/itf \
Path for include ASM files
PATH_I = $(PATH_H)
Absolute paths for Object files
PATH_EXT_OBJ = \
Root paths for Object files
PATH_ROOT_OBJ = \
Absolute paths for Library files
PATH_EXT_LIB = \
Root paths for Library files
PATH_ROOT_LIB = \
endif
The line 4 is: ifndef MAKEFILE_INCLUDED
Regards,
Ioannis
Oh! That looks OK to me…
I have no idea why it doesn’t do the trick…
Best Regards,
Jan
Hi Jan,
Probably, I will ask wavecom directly.
Thanks anyway.
Regards,
Ioannis
