Hello all,
Has anyone been able to successfully use the Slow Idle mode when connected to TCP via SIM/GPRS control?
For example what I would like to do is the following:
- Power up
- Initiate w32k=1
- DTR low (disabling low power mode)
- Subscribe to SIM with pin
- On SIM event FULL_INIT start connection to GPRS
- Once GPRS connected start TCP connection
- Once TCP connected communicate to host
- Once successfully communicated to host set DTR High (enabling low power mode)
- Now in low power mode (after x seconds) until timer event happens
(using Oasis 2.10 with a 2686h CPU)
What I am initially doing is testing that the device can go into low power mode after a successful SIM init but when I trigger the DTR line high at this point and after waiting longer than 15s (as stated in documentation) the device dose not go into slow idle mode, hence, if i cannot get this to work then I cannot see it working after all the other items above have been done.
I have managed to achieve low power mode before attempting the sim action above.
Anyone have any ideas about this?
On this basis I have tried another approach, i.e. trying to use the slow standby mode. I know this does not give you the functionality that slow idle mode gives.
For example what I have tried so far is this:
- power up.
- start a regular timer to perform set operations, including reading at+wbhv=1,x state.
- adl_atUnSoSubscribe to commands “+CALA:”.
- Set an Alarm using the at command at+cala.
- When alarm event happens:
- send internal command for a new alarm to trigger.
- send internal commands at+wbhv=1,2, Set DTR low via GPIO then perform a internal at+cfun=1 operation.
- After x seconds of the unit having restarted the unit goes into low power mode.
- When next alarm event happens (during slow standby mode):
- send internal command for alarm trigger (to go back into slow standby mode), at+cala.
- send internal commands at+wbhv=1,0 then perform a internal at+cfun=1 operation.
The idea being that the application will loop round and round going between slow standby and default modes.
The problem I am having with this idea is that after the last stage above I am not seeing the device come back to the default mode (Fast Idle Mode), anyone have any idea’s??
Barry
