To reduce power consumption wavecom modules have ON/~OFF pin. If this pin is set to HIGH than issuing AT+CPOF command just switches off GSM part of module. This mode does not save much power cause GSM is designed to consume as low power as possible. But if you set this pin to LOW than your module will be entierly switched off after AT+CPOF. I think it is the lowest consumption mode ever.
