pointer config
smsSend=adl_smsSend(smsSu,phonenumber,CmdCreate ,ADL_SMS_MODE_TEXT);
for this code i got error messsage of:
"passing arg 3 of ‘adl_smsSend’ makes pointer from integer without a cast [Conflicting names][applic.c] "
What does this error mean?
this is our original code
ascii phonenumber[20]="+6594868899";
ascii SmsTel[20]="+6581507582";
ascii SmsTimeorLength[20]="1000";
ascii SmsText[20]="hi";
ascii smsSu,CmdSu,CmdCreate;
ascii u;
u32 smsSend;
s16 smsUn,CmdUn;
bool SMS_TELE_Handler(ascii *SmsTel, ascii *SmsTimeOrLength, ascii *SmsText)
    return TRUE;
void SMS_TELE_ctrl_Handler ( u8 Event, u16 Nb )
switch ( Event )
    case ADL_SMS_EVENT_SENDING_OK :
    TRACE (( 1, "Report OK" ));
    break;
    case ADL_SMS_EVENT_SENDING_ERROR :
    TRACE (( 1, "Report sending error %d", Nb ));
    adl_atSendResponse ( ADL_AT_UNS, "\r\nFailed...\r\n" );
if ( Nb == 512 )
    TRACE (( 1, "Retry later..." ));
break;
ascii ADC_Response_Handler (adl_atResponse_t *paras)
    //CmdCreate=adl_atCmdCreate("at+adc?\x1A",  ADL_AT_PORT_TYPE( ADL_AT_UART1, TRUE ),(adl_atRspHandler_t)ADC_Response_Handler, "+ADC: ", NULL);
return TRUE;
void tele_tmrRetryHandler ( u8 ID )
    CmdCreate=adl_atCmdCreate("at+adc?\x1A", ADL_AT_PORT_TYPE( ADL_AT_UART1, TRUE ) , (adl_atRspHandler_t)ADC_Response_Handler, "+ADC:", NULL);
    smsSu=adl_smsSubscribe( SMS_TELE_Handler, SMS_TELE_ctrl_Handler, ADL_SMS_MODE_TEXT );
    smsUn=adl_smsUnsubscribe(smsSu);
    TRACE ((1, " Send Command: %d ", CmdCreate));
    TRACE ((1, " Send SMS: %d ", smsSu));
    TRACE ((1, " Send SMS: %d ", smsSend));
    TRACE ((1, " Send SMS: %d ", smsUn));
    adl_tmrSubscribe ( FALSE, 200, ADL_TMR_TYPE_100MS, tele_tmrRetryHandler );
best regards ,
Thia
It means exactly what it says!
You can see which is arg (short for argument - or “parameter”) 3, can’t you?
You can see what you’ve supplied for that argument, and what type it is;
You can look-up the definition of adl_smsSend, and see what type it requires for its 3rd argument…
hi anweii,
i look up the adl_smsSend the 3rd argument for this is ascii type and i want to ask is it possible to change the 3rd argument to other type?
or how can i get the result from the terminal emulator and put it in the the 3rd argument of adl_smsSend?
best regards
thia
No, it isn’t - look again!
No - the function is provided by Wavecom as described.
What result?
     Yes, the third arugment is ascii SmsText; .
AUG_OpenAT_ADL_Development_Guide-004.pdf, page: 61 of 103
We want to return the value that I show in this photo.
We are mesuring the meter and want to send the value through sms .
http://i274.photobucket.com/albums/jj277/metalfonix/resultsfromterminalemulator.jpg
best regards,
Thia
Not in my copy, it isn’t:
[attachment=0]adl_smsSend.gif[/attachment]
That is an Unsolicited Response - so look at adl_atUnSoSubscribe
