Ping issue with HSIC Bridge to Ethernet adapter mangOH_red
Hi ,
I had the IOT Card conencted to mangoh_Red and the ip address is assigned from the local dhcp server of the network.
I am able to ping the server from the board.
However the ping to the board from server is not working
I am wondering is that any firewall is enabled on the modem by default . If this is not the technical reason then what could be the reason why the ping doesn’t work in the other direction.
Please let me know if you need more info.
Any help much appreciated.
Best Regards,
SIva
I would suggest reviewing the section on Firewall rules here:
https://docs.legato.io/latest/basicTargetConfigETH.html
Regards,
Kevin
