Does the OAT timer interface provide functions to create periodic timers. I need to create periodic timers for long term events (minutes, hours, days etc). I have not found any info relating to this subject. If someone could kindly point me in the right direction I would greatly appreciated.
Given that the stated requirement was, “long term events (minutes, hours, days etc)”, I think that limitation can probably be tolerated in this particular case… 8)
Or in case of long periods you should get the RTC time through Open AT api with a fast cyclic timer and compere it to a reference point ( which you can keep in flash ) to trigger a long period event.
You obviously don’t want to loose your counter before 1 second of the long period because of a reset.
To All,
Thank you for your responses to my problem. This is a great forum and I look forward to contributing to the forum when I can. Thanks again for all your help.
