Are the compiler switches for M2MStudio this release different from the old cygwin based SDK. I’m noticing that the same code is compiling to 1-2% bigger with M2MStudio. Any thoughts on which compiler switches changed?
I have an OpenAT application that is around 500K in size, which results in a lot of wasted time to download images during development. Any ideas on any additional compiler switches that can be turned on to decrease the image size?
Optimisations have been set to -O0 in Debug configuration (stayed at -O2 in Release configuration), to ease step by step debugging while using JTAG.
You can restore former behaviour by editing compiler options of your projet.
I’m using the release build. I noticed I didn’t put that in the original message. Also, I am using RVDS. So the RVDS Release build in the new environment is a few percent bigger than the normal build in the old environment.
Are there any other optimization settings that may have changed other than “-O3”.
Strange, we didn’t change the options of the RVDS compiler between the old IDE and M2M Studio. Are you sure you’re using the same packages versions (Open AT OS and Plug-ins) that the ones you were using before?
This could explain the difference…
