Office-based CSD/USSD Server?
Hi
It’s possible to have 2 GSM modems dial one another to set up a data connection. If there is a central office, with, say, 100 satellite modems, having the office modem dial each satellite modem (or vice-versa) in turn is not a good solution.
If the satellites could dial a number for which there could be numerous (virtual) lines then that would be an advantage. A VOIP phone system would appear to fit the bill for this. Are there any standard products that provide such a dial-up service that would allow numerous remote GSM modems to connect to an office LAN using CSD?
Yes.
Yes, that is the fundamental scalability problem with any circuit-switched arrangement!
I guess you should look to how ISPs do (or did) this to support dial-up customers…
In principle, it should be possible for the networks to provide this sort of thing as an “interworking function” - but I suspect they’d rather you used GPRS these days…
ISDN-30, etc,… :question:
Edit - something like this: data-connect.com/Patton_2960_30.htm :question:
“120-Port, V.92/V.110/V.90/ISDN, Dial-Up Remote Access Server (RAS)”
Eek! $10,000 for one of those!
There’s always a catch! 8)
This might be the right sort of device - supporting “modem over IP”:
data-connect.com/Quintum_Tenor_AS.htm
I guess another possibility could be to use USSD for inbound messages.
telecomspace.com/forum/index.php?topic=489.0
en.wikipedia.org/wiki/USSD_Gateway
krvarma.com/?p=242
activexperts.com/xmstoolkit/sms/ussd/
" You need to approach every operator and get a SMPP account opened with the operator"
Has anyone done this?
Is there a guide anywhere on how to install a handler on the mobile network to catch them?
I guess that’s the real killer?!
Could you not just use SMS?
Yes but SMS messages can sometimes be queued. For hours.
True - possibly even days?
Example: viewtopic.php?f=11&t=4499&p=18133#p18133
Fixed link:
https://forum.sierrawireless.com/t/speed-of-gsm-modem-fasttrack-supreme-20/4124/1
