Hello All.
In my application the edge action send data to SF which ends in the :default
stream.
The stream capacity is set to 1000 events. The device runs for several weeks and produced far more than 1000 events (around 90000 at this very moment).
According to documentation:
Capacity. This sets the maximum number of events that can be stored within the Stream. The default value is 1,000 and the maximum is 100,000. When the Stream exceeds its capacity of Events, older Events will be deleted automatically. If the capacity is set to 0, no Events are saved; if the capacity is set to 1, the same Event is overwritten every time a new Event occurs.
Nevertheless, I can fetch all 90k events from the stream using the FindEvent API function nicely. Looks like those 89k events weren’t overwritten.
- Why is that possible? Do I misunderstand the capacity setting?
The GetStream function returns same ‘1000’ events capacity. Is there a reliable way to get that real amount of events available in the stream?
thanks in advance!
Hello Alex,
You are correct in your notes on how the stream capacity should work. I have not tested this in some time. Can you send me the link to the default stream so I can examine it? I will test in my account as well and enter a ticket if needed? Thank you in advance.
Hello Alex,
I tested adding more events to edge and cloud streams and you are correct that the limits are not being observed. I will enter a ticket to engineering.
You can count the number of events in a stream with Octave REST API Documentation
Many thanks for your post!
Hello @djudkins ,
glad my work might contribute to improving of Octave API.
The ID of the stream I’m talking about is s6398a3237cb56a6c23186cd0.
Interestingly, yesterday afternoon (CET time) I noticed the ability to get all those 10000s of events from this stream disappeared. If I ask my script to download all events from the stream now I get total 1100 events. Did Sierra do something already?
As an evidence to my previous statements I have a file containing all the unique event IDs of nearly 90k real events which I fetched two days ago when it was still possible.
Thanks for pointing out at CountEvent function, I might try it in future.
