Not able to connect to the network and see GPS is working or not
thanks. here i am not getting any reposnse via “cm”…i have looked and checked AT commands as here "cm radio" not working
all are getting but cm does not working…i have upgraded the FW (AT&T one ) recently
https://source.sierrawireless.com/resources/airprime/software/wp77xx/wp77xx-firmware-latest-release/#sthash.lfUofm4s.QV1z8yCt.dpbs
What is the return of “legato status” ???
Why was it working in the past but not working now?
i actually dont know, it was working perfectly !!! suddenly it is like this. Actually, legato status was not responding and installed a new FW via windows and getting the status. AT commands are given below:
C:\Users\tariq>ssh root@192.168.2.2
root@swi-mdm9x28-wp:~# microcom /dev/ttyAT
Model: WP7702
Revision: SWI9X06Y_02.36.06.00 63d944 jenkins 2020/12/10 19:12:28
IMEI: 352653090405390
IMEI SV: 6
FSN: 4L031671151310
+GCAP: +CGSM
Current Operating Mode: 0x2
Supported Operating Modes:
LTE WB: 0x01
LTE M1: 0x02
LTE NB1: 0x04
ERROR
!GSTATUS:
Current Time: 18590 Temperature: 36
Reset Counter: 1 Mode: ONLINE
IMS reg state: UNKNOWN IMS mode: Not Support
IMS Srv State: UNKNOWN SMS,UNKNOWN VoIP
LTE band: B12 LTE bw: 10 MHz
LTE Rx chan: 5060 LTE Tx chan: —
LTE CA state: INACTIVE
RRC state: RRC Idle
PCC RxM RSSI: -86 RSRP (dBm): -115
PCC RxD RSSI: 0 RSRP (dBm): 0
Tx Power: – TAC: 61E4 (25060)
RSRQ (dB): -12 Cell ID: 0103A809 (17016841)
SINR (dB): 1.2
+CGDCONT: 1,“IPV4V6”,“iot0119.com.attz”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 2,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 3,“IPV4V6”,“”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
+CGDCONT: 4,“IPV4V6”,“attm2mglobal”,“0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0”,0,0,0,0
may be need updated FW? what do you think?
I don’t know, you can try different firmware
can i have the links of the latest FW?
How about this?
https://source.sierrawireless.com/resources/airprime/software/wp77xx/wp77xx-firmware-release-15,-d-,1/
i tried few of them…now i am not getting legato status !!! legato is not running !!!
How about start it by “legato start”
getting error
no idea why your module suddenly has problem…
see if downloading and performning recovery mode can help
FW is updated and it works now…dont know why it happened !!!
I have another issue with “gpsAPP”
where “map locate” in not giving output once we run the “gpsApp”.
it says a note that where we are using wp77
Have you tried with wp76 then?
Have you tried with at!GPSFIX command first?
Or you can simply use gnss command
