I updated the firmware on my MangOH Yellow, but now I am not able to connect to the wifi. I see that wlan0 interface is not listed in ifconfig -a
root@swi-mdm9x28-wp:~# ifconfig -a
bridge0 Link encap:Ethernet HWaddr 0A:F8:CF:65:1D:77
inet addr:192.168.225.1 Bcast:192.168.225.255 Mask:255.255.255.0
inet6 addr: fe80::8f8:cfff:fe62:1a74/64 Scope:Link
UP BROADCAST MULTICAST MTU:1500 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:1 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:0 (0.0 B) TX bytes:76 (76.0 B)
ecm0 Link encap:Ethernet HWaddr 3E:DE:E0:90:9D:CC
inet addr:192.168.2.2 Bcast:192.168.2.255 Mask:255.255.255.0
inet6 addr: fe80::3cde:e0ff:fe90:9dcc/64 Scope:Link
UP BROADCAST RUNNING MULTICAST MTU:1500 Metric:1
RX packets:646 errors:0 dropped:0 overruns:0 frame:0
TX packets:365 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:58467 (57.0 KiB) TX bytes:53666 (52.4 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
RX bytes:76 (76.0 B) TX bytes:76 (76.0 B)
rmnet0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
UP RUNNING MTU:2000 Metric:1
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
rmnet_data0 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
[NO FLAGS] MTU:1500 Metric:1
rmnet_data1 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data2 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
rmnet_data3 Link encap:UNSPEC HWaddr 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00
sit0 Link encap:IPv6-in-IPv4
NOARP MTU:1480 Metric:1
and when I try to run command, and logread on another terminal, here is the information:
root@swi-mdm9x28-wp:~# wifi client start
ERROR: le_wifiClient_Start returns ERROR.
ravneetsingh@RavneetPersonal:~$ ssh root@192.168.2.2
root@swi-mdm9x28-wp:~# logread -f | grep wifi
Jul 12 16:11:45 swi-mdm9x28-wp user.warn Legato: -WRN- | supervisor[1232]/supervisor T=main | proc.c GetWatchdogAction() 362 | wifi@0 watchdogAction ‘’ in proc section
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | app.c app_Start() 3471 | Starting app ‘wifi’
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | app.c CreateFileLink() 2084 | Skipping file link ‘/legato/systems/current/apps/wifi/read-only/lib/libComponent_wifi.so’ to '/legato/systems/current/appsWriteable/wifi/lib/libComponen
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | app.c CreateFileLink() 2084 | Skipping file link ‘/legato/systems/current/apps/wifi/read-only/bin/wifi’ to ‘/legato/systems/current/appsWriteable/wifi/bin/wifi’: Already exists
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | proc.c proc_Start() 1403 | Starting process ‘wifi@0’ with pid 4896
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | supervisor[4896]/supervisor T=main | proc.c proc_Start() 1363 | Execing ‘bin/wifi’
Jul 12 16:11:45 swi-mdm9x28-wp user.debug Legato: DBUG | wifiService[3346]/framework T=main | unixSocket.c ExtractFileDescriptor() 34 | Received fd (12).
Jul 12 16:11:45 swi-mdm9x28-wp user.debug Legato: DBUG | wifiService[3346]/framework T=main | unixSocket.c ExtractFileDescriptor() 34 | Received fd (13).
Jul 12 16:11:45 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | WIFI_START
Jul 12 16:11:45 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | /etc/init.d/cywifi:
Jul 12 16:11:45 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | line 109:
Jul 12 16:11:45 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | can’t create /sys/devices/platform/expander.0/wl_reg_on: nonexistent directory
Jul 12 16:11:49 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | Cypress chip MMC recognition may have been overwritten
Jul 12 16:11:49 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/compat.ko’: File exists
Jul 12 16:11:49 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/cfg80211.ko’: File exists
Jul 12 16:11:49 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmutil.ko’: File exists
Jul 12 16:11:49 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmfmac.ko’: File exists
Jul 12 16:11:54 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | wlan0 interface was not created by Cypress drivers
Jul 12 16:11:54 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | WiFi reset
Jul 12 16:11:57 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | /etc/init.d/cywifi:
Jul 12 16:11:57 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | line 109:
Jul 12 16:11:57 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | can’t create /sys/devices/platform/expander.0/wl_reg_on: nonexistent directory
Jul 12 16:12:01 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | Cypress chip MMC recognition may have been overwritten
Jul 12 16:12:01 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/compat.ko’: File exists
Jul 12 16:12:02 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/cfg80211.ko’: File exists
Jul 12 16:12:02 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmutil.ko’: File exists
Jul 12 16:12:02 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmfmac.ko’: File exists
Jul 12 16:12:07 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | wlan0 interface was not created by Cypress drivers
Jul 12 16:12:09 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | /etc/init.d/cywifi:
Jul 12 16:12:09 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | line 109:
Jul 12 16:12:09 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | can’t create /sys/devices/platform/expander.0/wl_reg_on: nonexistent directory
Jul 12 16:12:14 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | Cypress chip MMC recognition may have been overwritten
Jul 12 16:12:14 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/compat.ko’: File exists
Jul 12 16:12:14 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/cfg80211.ko’: File exists
Jul 12 16:12:14 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmutil.ko’: File exists
Jul 12 16:12:14 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmfmac.ko’: File exists
Jul 12 16:12:19 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | wlan0 interface was not created by Cypress drivers
Jul 12 16:12:22 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | /etc/init.d/cywifi:
Jul 12 16:12:22 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | line 109:
Jul 12 16:12:22 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | can’t create /sys/devices/platform/expander.0/wl_reg_on: nonexistent directory
Jul 12 16:12:26 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | Cypress chip MMC recognition may have been overwritten
Jul 12 16:12:26 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/compat.ko’: File exists
Jul 12 16:12:26 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/cfg80211.ko’: File exists
Jul 12 16:12:26 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmutil.ko’: File exists
Jul 12 16:12:26 swi-mdm9x28-wp user.err Legato: =ERR= | wifiService[3346] | insmod: can’t insert ‘/lib/modules/3.18.140/backports/brcmfmac.ko’: File exists
Jul 12 16:12:31 swi-mdm9x28-wp user.info Legato: INFO | wifiService[3346] | wlan0 interface was not created by Cypress drivers
Jul 12 16:12:31 swi-mdm9x28-wp user.warn Legato: -WRN- | wifiService[3346]/daemon T=main | pa_wifi_client.c pa_wifiClient_Start() 532 | Failed to start WiFi client command “WIFI_START” systemResult (32512)
Jul 12 16:12:31 swi-mdm9x28-wp user.warn Legato: -WRN- | wifiService[3346]/daemon T=main | le_wifiClient.c le_wifiClient_Start() 821 | Unable to start WIFI client; return code: -6
Jul 12 16:12:31 swi-mdm9x28-wp user.debug Legato: DBUG | wifiService[3346]/framework T=main | le_wifiClient_server.c CleanupClientData() 163 | Client 0x7f56c450 is closed !!!
Jul 12 16:12:31 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | proc.c proc_SigChildHandler() 2079 | Process ‘wifi@0’ (PID: 4896) has exited with exit code 1.
Jul 12 16:12:31 swi-mdm9x28-wp user.debug Legato: DBUG | wifiService[3346]/framework T=main | le_wifiAp_server.c CleanupClientData() 163 | Client 0x7f56c3c0 is closed !!!
Jul 12 16:12:31 swi-mdm9x28-wp user.warn Legato: -WRN- | supervisor[1232]/supervisor T=main | app.c app_SigChildHandler() 4066 | Process ‘wifi@0’ in app ‘wifi’ faulted: Ignored.
Jul 12 16:12:31 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | app.c app_StopComplete() 4753 | app ‘wifi’ has stopped.
Jul 12 16:12:31 swi-mdm9x28-wp user.info Legato: INFO | supervisor[1232]/supervisor T=main | apps.c DeactivateAppContainer() 374 | Application ‘wifi’ has stopped.
Will be grateful for any help/suggestions!! Thanks a lot!!
