No backtraces
Hello, I’m using SL6087 ,
Open AT applicaation Framework Package 2.52.0.20137100830
Developer Studio 2.3.2.201310241753
Firmware Package 7.52.0.201306260837
OpenAT OS Package 6.52.0.201306271400
Why can’t I see any backtraces when I choose the .axf File, it display No Backtraces … ??
and thank you in advance
Hiya,
Have you refreshed the view after connecting the AXF file? Use the double arrow symbol above the AXF Browse button to download the backtraces from your modem.
Note that the modem must be connected and the port open before you can download the backtraces.
Also, I’m not sure if the backtraces are available in a ‘release’ version of your application.
ciao, Dave
Backtraces are recorded whatever if the app is in Debug or in Release mode.
As a reminder, backtraces are records of the call stack when there is a software crash leading to a device reset.
If the view says “No backtraces”, then nothing is recorded on the device. To get some, you should try to reproduce the crash you want to analyse (if you can), and refresh the backtraces view again.
