Hi, I am trying to connect to a device attached to my cell modems serial port. However I am unable to authenticate, the terminal keeps returning:
Permission denied, please try again.
I am using the sconsole account, I am connected locally and have tried resetting the password to a few different phrases but all with no luck. I am able to log into the standard user account but it is of no use as it logs into the standard AT terminal not my serial device. I have this working on the GX440 and any help would be great.
Here is an excerpt from the log:
Sep 12 17:37:54 info dropbear[16697]: Child connection from 192.168.0.223:51968
Sep 12 17:37:54 warn dropbear[16697]: User ‘sconsole’ has invalid shell, rejected
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12229 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12363 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12230 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12364 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12231 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12365 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12232 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12366 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12233 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12367 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12234 for processSET
Sep 12 17:37:56 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12368 for processSET
Sep 12 17:37:58 warn dropbear[16697]: User ‘sconsole’ has invalid shell, rejected
Sep 12 17:38:13 warn ALEOS_ALMS_LWM2M: Failed bootstrap, retrying in ‘160’ seconds, ‘0’ left
Sep 12 17:38:17 warn dropbear[16697]: User ‘sconsole’ has invalid shell, rejected
Sep 12 17:38:20 warn dropbear[16697]: User ‘sconsole’ has invalid shell, rejected
Sep 12 17:38:20 info dropbear[16697]: Exit before auth (user ‘sconsole’, 3 fails): Exited normally
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12229 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12363 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12230 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12364 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12231 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12365 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12232 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12366 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12233 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12367 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12234 for processSET
Sep 12 17:38:32 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12368 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12229 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12363 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12230 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12364 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12231 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12365 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12232 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12366 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12233 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12367 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12234 for processSET
Sep 12 17:39:07 err ALEOS_SYSTEM_CSM: processSET : Failed to add 12368 for processSET
