Mos_header
Hi
When i try to compile my project i get an error “cannot find mos_header.o”
How do i create this ?
Best regards
Henrik
Can you give details on how you have created your project?
Did you try just with a simple Hello_World sample project?
Hi
I have tryed to make the Hello world sample.
Compiled Ok but when I try to download it from M2M it fails.
The Remote shell responds with.
at+wdwl
+WDWL: 0
*** ERROR IN HEADER ***
at
at+cfun=ý
Are you sure the SDK/Software Suite profile you are using for your project is compatible with the wcpu you are using (and also compatible with the Firmware version currently running on the target)?
Correct - that was the problem.
Im having the same errror message. I have a Fastrack Supreme Wavecom modem with an AT V4.20 and firmware Version 6.63.
Which is the correct project profile for my device? Also, where can I download it or find it?
Best regards.
Such compatibility topics should be posted on other forums than this M2M Studio dedicated one…
However, to help you, you have to download an SDK compatible with your hardware.
  • Go to wavecom.com
  • Log in
  • Go to products > Fastrack Supreme
  • Go to Downloads > Archive
  • Grab the last Open AT SDK v4.2*
  • Don’t execute the exe file, but import packages in M2M Studio (File > Import > M2M Studio > Packages from IDE V1 > Browse to the exe file)
  • Make your project use this profile configuration… (Project Properties > Open AT Application)
