Is it possible to setup a monthly data usage limit on a LS300 ?
Best regards
You can only limit mobile network communication until the end of the billing period when the data limit is reached by blocking connected LAN devices from using the mobile network. Traffic sent to and from the AirLink gateway is not blocked. Over-the-air access to ACEmanager and the Telnet/SSH AT interface is still available.
- In ACEmanager, go to Applications > Data Usage.
- In the Usage Monitoring field, select Enable.
