Actually Module got tilted in the board so it getting short with ground. After tracking the other lines, SIM holder lines are also getting short with nearby pins in Module.
We planned to desolder the HL Module and place it again correctly in the board.
Due to the above problem whether module will damage? or we can able to reuse the Module.
Well, you’ve already identified a couple of pretty gross errors - so who knows what else may have happened…?!
I think you need to assume that the likelihood of damage is quite high. So it would be best to start with fresh modules that you know are good - rather than potentially waste a load of time (ie, money) on weird issues which may or may not be due to this abuse …
