Hello all,
Does MC7750 support CDMA/EVDO Only (instead of LTE to EVDO fallback)?
I show the ESN number being displayed via AT command both in HEX and DEC format.
Regards,
Hello all,
Regards,
Does network registration works in automatic mode (LTE/CDMA) and fallback?
If yes and if you want it to run only in CDMA/EVDO mode, you may try !SELRAT command, check the options available using “AT!SELRAT=?”, refer to Standard AT command guide for more details.
Hope it helps.
L
