I’m really getting crazy about this. To be sure about the parameters I connect the modem via the AT commands interface. Exactly, issuing these commands:
AT!BAND=0 //all bands
AT!SELRAT=3 //the setting is found after connecting the modem under windows
AT!SCACT=1,1 //where 1 is the correct profile
then
#dhclient wwan0
After that i’m connected but the connection speed is not even comparable to the one that i get with the same modem/operator under windows.
Do you have the same problem in QMI mode? I haven’t tested DirectIP much, so I don’t know how it compares, but I have noted that the protocol framing put some load on the firmware. FWIW, I have no problems achieving speeds up to 80 Mbits/s down and 40 Mbits/s up under normal network conditions using QMI or MBIM on Linux.
