I’m having a problem with my MC7700 under Linux. I have it hooked up to a dev kit, which is connected via USB to a Linux machine running the latest stable Ubuntu build. The card connects and starts working, I can see is with lsusb, and I can talk to it with cutecom. I sent it some AT commands and it responded correctly.
After maybe 30-45 seconds, it stops responding to my input. All input stops working and it won’t echo anything I send it (in one case it was in the middle of echoing my last command when it stopped). I used dmesg and it shows tons of these:
wwan0: Submit SYNC failed -32
wwan0: Send SYNC failed, status -32
These are printed over and over every few seconds. I’m confused – I haven’t ordered it to do anything. What’s failing? What I observed was identical to this:
en.usenet.digipedia.org/thread/19505/1297/
I don’t know what to do differently; all I did was look at the APNs and do ATI and ATE1. It still stops communicating if I don’t do anything at all. Is there some driver or firmware I need to install? It seems to be recognized fine, but it quits working quickly. Any help would be appreciated, thanks.
