Hello everybody. Installed this Sierra Wireless MC7700 into a mk3 Panasonic CF19K. Driver installed without problems . The conection manager Skylight also installed. Configured one profile for APN … Network selection left on Automatic. It conect to (DIGI) the provider of the SIM card belong on 2G EDGE at ridiculos 3kbps. Windows say: Internet access … but the browsers dont catch anything … If i change in Skylight to Manual network selection, it search for a while and give me a list with a bunch of providers … If I chose the 3G DIGI or 4G DIGI provider, I get No Service. I know 100% that this provider NOT have DATA service broadcast on 2G or 3G. On 2G DIGI have the GSM voice, 3G was totaly closed
DIGI provider have ONLY 4G LTE on the folowing frequences:
2100 Mhz (band 1 - FDD) - 75 Mbps download și 21 Mbps upload
2600 Mhz (band 38 - TDD) - 100 Mbps și 10 Mbps upload
I really not know why I get no service on 4G LTE selecition.
I called the support center and they not want to listen to my problem they know only “phones” … not laptops
Thanks for any input
are you using the latest FW?
do you see any modem port in device manager?
if yes, you can enter
AT!GSTATUS?
ati3
at+cfun?
at+cpin?
Hello! Many thanks for your time man
Here are the responds of your comands (sent by the AT Command Tester software):
Sending AT query…
Successfull response for AT query…
Enabling echo and verbose mode
AT+CGMM
MC7700
Model Number : MC7700
AT+CGMI
Sierra Wireless, Incorporated
Manufacturer : Sierra Wireless, Incorporated
AT!GSTATUS?
!GSTATUS:
Current Time: 351 Temperature: 26
Bootup Time: 1 Mode: ONLINE
System mode: LTE PS state: Not attached
LTE band: No band LTE bw: Unknown
LTE Rx chan: 65535 LTE Tx chan: 65535
EMM state: Deregistered No Cell
EMM connection:RRC Idle
RSSI (dBm): 0 Tx Power: 0
RSRP (dBm): 0 TAC: 0000 (0)
RSRQ (dB): 0 Cell ID: 00000000 (0)
SINR (dB): -20.0
ATI3
Model: MC7700
Revision: SWI9200X_03.05.20.03ap r5600 carmd-en-10527 2012/11/18 12:06:50
IMEI: 012626001824653
IMEI SV: 15
FSN: CDC0874306910
3GPP Release 8
+GCAP: +CGSM
AT+CFUN?
+CFUN: 1
Device has Full functionality.
AT+CPIN?
+CPIN: READY
SIM is ready
About the using latest FW… I had try all the FW versions from the MC7700 Firmware Package History download page. None change the actual situation.
Should I program [MC7700 ATT approved firmware SWI9200X 03.05.29.03 QMI] the latest FW again?
Thank you and Best regards
How about
AT!ENTERCND=“A710”
AT!BAND?
AT!BAND=?
Not sure if your module supports band 1…
BTW, you can try the latest FW and see what happens.
AT!ENTERCND=“A710”
Password protected commands are unlocked
AT!BAND?
Unknown band mask. Use AT!BAND to set band.
000000000CE80380 0000000000010009
Current Band Index is 000000000CE80380 0000000000010009
AT!BAND=?
Index, Name, GW Band Mask L Band Mask
00, All bands, 000000000CE80380 0000000000010008
01, Europe 3G, 0000000000400000 0000000000000000
02, North America 3G, 0000000004800000 0000000000000000
03, Europe 2G, 0000000000000380 0000000000000000
04, North America 2G, 0000000000280000 0000000000000000
05, GSM ALL, 0000000000280380 0000000000000000
06, Europe, 0000000000400380 0000000000000000
07, North America, 0000000004A80000 0000000000000000
08, WCDMA ALL, 000000000CC00000 0000000000000000
09, LTE ALL, 0000000000000000 0000000000010009
0000000000010000 - B17
0000000000000008 - B4
0000000008000000 - B6 (800)
0000000004000000 - B5 (850)
0000000000800000 - B2 (1900)
0000000000400000 - B1 (2100)
0000000000200000 - G1900
0000000000080000 - G850
0000000000000200 - G900P
0000000000000100 - G900E
0000000000000080 - G1800
have you entered correct APN for this SIM card in AT+CGDCONT?
I think yes. This provider require APN: internet …
AT+CGDCONT?
+CGDCONT: 1,“IP”,“internet”,“0.0.0.0”,0,0
Following connection profiles are available,
CID-> 1
PDP Type->IP
APN->internet
PDP Address->0.0.0.0
Data Compression->0
Header Compression->0
This look strange to me… in the skylight after search, I chose the provider DIGI 4G , but when I return to network selection, available networks, it say *Unknown
can you sim card register LTE network on band 1?
It is strange that AT!GSTATUS shows not registered.
I dont know… the provider say his 4G DATA are on 2100 Mhz (band 1 - FDD) and 2600 Mhz (band 38 - TDD)
I put the SIM card into a tablet and configure APN: internet and it conect just fine on LTE 4G.
Something is wrong on my side…
It conects only on 2G GPRS EDGE where the provider not have data service… just GSM voice (and posible internet over the GSM). This SIM is only DATA to use modems or tablets. Tested well into a Google NEXUS 7 2013
does it connect band 1 in your google phone/tablet?
Google NEXUS is a 7 inch tablet it have no GSM (phone) capability. I have no ideea on what band it conects.
Back to laptop. If I choose in Skylight after network search… if I choose the 2G DIGI I get this:
AT!GSTATUS?
!GSTATUS:
Current Time: 5203 Temperature: 32
System mode: GSM PS state: Attached
GSM band: GSM900
GSM channel: 24
GMM (PS) state:REGISTERED NORMAL SERVICE
MM (CS) state: IDLE NORMAL SERVICE
Serving Cell: 22 (GSM 900 )
RX level (dBm): -54.7500 LAC: 02BC (700)
GPRS State: GPRS STANDBY Cell ID: 0000A7E5 (42981)
Windows even say Internet access… everything look ok but it not have real access… in browser the google page open in 10 minutes for real… browser say no internet conection or site take too long time to respond
When swich to 4G DIGI from the search list I say no service (in list there are more providers but the others are forbiden)
there should be some android application to show what band it is connecting in tablet
Will pull out the SIM and put it into tablet then search for a program that is able to show the bands… Will get back shortly
The LTE Discovery state the following:
226 05 LTE B1
GCI: 01D9D215
TAC: 700
PCI: 213
DL EARFON: 24
UL EARFON: 18024
DL FREQ: 2112.40 MHZ
UL FREQ: 1922.30 MHZ
BANDWIDITH: 2147483647
SIM 1 READY
CARRIER: DIGI.MOBIL (226 05)
NETWORK TYPE: LTE
IS ROAMING: FALSE
IS CAPABLE: TRUE
TYPE: NONE
MODEL: ASUS NEXUS 7 (GOOGLE)
VERSION: ANDROID 10
how about setting the band to AT!BAND=0 ?
BTW, do you have other operator to test?
I had give that comand early when I read “Unknown band mask. Use AT!BAND to set band.”
Comand ok, but nothing changed, no service in the Skylight
I have no other SIM from some other provider… When scan there are others like vodafone or orange … they are forbiden,
Why it conect 2G GPRS EDGE
no idea, you need to check with operator Digi
have you tried newer FW?
I have call them and they not wanna hear of this sort of problems. Only phones… they probably know only to browse phone menu and set APN: internet and that’s all.
I program all the FW that was on the official page…
I have no ideea what is the difference between the DIP and QIM … one worked to program the other dont
the only advice left is to test on other operator
