[Platform]Linux
[FW version]03.05.19.00A
[QMI Driver Version]S2.11N2.17
[SDK Version]SLQS03.01.03
How do you set multiple APN in MC7700?
Currently, MC7700 can activate APN that is only cid#1.
Please see following is my test result.
1st test setting CID#1 : mopera.net CID#2 : pre4657.xi.dcm.ne.jp2nd test setting(cid# switching)
CID#1 : pre4657.xi.dcm.ne.jp
CID#2 : mopera.net
*Of course, a SIM that we are using as test supports both APN.
I.Send AT Command as follows ・at+cgdcont=1,"IP","mopera.net" ・at+cgdcont=2,"IP","pre4657.xi.dcm.ne.jp" ・at!reset II.★After the module power on, Activate CID#1 APN by Connection Manager that is one of QMI SDK Sample Application. III.Finish SDK and the module is reset by AT!RESET IV.★After the module power on, Activate CID#2 APN by Connection Manager that is one of QMI SDK Sample Application. V.Finish SDK and the module is reset by AT!RESET VI.Send AT Command as follows(Switch CID#) ・at+cgdcont=1,"IP"," pre4657.xi.dcm.ne.jp " ・at+cgdcont=2,"IP"," mopera.net" ・at!reset VII.★After the module power on, Activate CID#1 APN by Connection Manager that is one of QMI SDK Sample Application. VIII.Finish SDK and the module is reset by AT!RESET IX.★After the module power on, Activate CID#2 APN by Connection Manager that is one of QMI SDK Sample Application. X.Finish SDK and the module is reset by AT!RESET XI.Check test result at ★II★After the module power on, Activate CID#1 APN by Connection Manager that is one of QMI SDK Sample Application.
LTE Data Session started successfully
Failed to start LTE/CDMA Data SessionFailure Code : 1014(0x03f6)
WDS Call End Reason : 1016(0x03f8)
Thank you.
–Takuya
