we are using a APU Board with the MC7455 modem and smstools 3 to sent sms with them.
Used Kernel is 4.9.0-bpo.
We are only using at commands to communicate with the modem.
At some point the modem will be resetted and reconnected to the system via udev rules and at commands.
Are there any known bugs with this hardware combination which could lead to a kernel crash?
Gobiserial drivers are not used.
This worked before on the same mainboard ,modem and the same software.
If I switch back to a older mainboard within the same series there is no issue.
Since this is a really strange behaviour we switched all the hardware components.
Without smstools running there is also no kernel crash, or at least I did not had one after a day.
I will write a script which resets the modem without smstools involved and test it for some time.
I have disabled smstools and have sent at commands (AT+CFUN=1,1) to the modem.
At some point it crashed again.
Also I have set all running crons to *****, after a wihile crashed again.
Without attached modem no issues with crons set to every minute.
No I do not have an excact log, but what happens is only this:
AT+CFUN=1,1
AT+CFUN=1,1
And so on.
The script:
#!/bin/bash
exisits=$(cat /var/run/sendcommands.pid)
if [ -z "$exisits" ]; then
if [ -L '/dev/gsm0' ]; then
echo -e -n 'AT+CFUN=1,1\015' > /dev/gsm0
else
udevadm control --reload-rules && udevadm trigger
fi
sleep 20
rm -f /var/run/sendcommands.pid
fi
The firmware of the modem: 02.33.03.00 which is the latest generic.
Yes, this command just resets the modem, which should not result in a kernel crash at all.
But after some resets the system runs into errors and the kernel will crash at some point, which should not happen.
I am talking about 100-200 times the reset command.
I will test this with a installed pfsense.
A system not communicating with the modem does not have issues.
