When NMEA GPS data is being sent to the NMEA port (initiated with a “echo $GPS_START >/dev/ttyUSB1”), the +CMGS command will not work to spec.
If the GPS sessions are stopped using !GPSEND=0,255, then the +CMGS command works as it should.
The issue is the response from the +CMGS command.
With GPS running we get:
+CMGS=30
Without GPS running, we get (and is correct):
+CMGS=30
Both ways will then accept the PDU, and send the SMS, but with GPS on, no +CMGS response is received, with GPS off, the response is received as it should be.
We are running SWI9X30C_02.24.03.00
Another person with an MC7430 also tested this, and has the same issue, so seems to be across multiple products.
Not sure who needs to be told about this, so hopefully someone from SW see this.
