MC7304 WERE SET TO OFFLINE
Hello everyone, I need some help from you all where before this mc7304 was working fibe on x220t running win 7 64 bit, Recently I’ve done a firmwsre update on generic series and successfull , but I couldn’t get access this mobile datas card via sierrs skylight because it show an errors ‘mobile datacard offline’. I would like to know how to resolve this error.
Can you send the following to the unit.
at+cmee=1
ati
at!pcinfo?
at!priid?
at!entercnd=“A710”
at!priid?
What did you use to upgrade the unit?
Hello Mr. Mat.
I haven’t tried that commands yet and I’m using release from sierra baby website “build4399approved7304.exe”. Prior to this MC7304 is working fine but after firmware update always come out with “no service”. How could I find out an original firmware that comes as a default for this MC7304. For information, I’m from Malaysia and believe MC7304 could cover my country a well.
If its on our site (source.sierrawireless.com) its official and it sounds like you have done the right thing. If you send the commands I should be able to tell what is happening better.
Hello Matt.
Have a good day. Please find attached for your kind perusal and reference. Prior to firmware update, this MC7304 is working fine and could access full LTE, but after firmware installation then “no service” were come out. I forgot to note down “default” firmware.
Regards,
Zainul
MC7304-AT.txt (926 Bytes)
Ok it looks like you have not upgraded the firmware as 4.5.23 is EXTREMELY old, this is not a problem and is also not causing the low power mode. The LPM is being caused by the W_Disable line being pulled down which is disabling the radio, its nothing to do with the software, if you are using a development kit it is a DIP switch setting.
Hello Matt,
YES. by default radio is OFF then via SKYLIGHT we’ll TURN ON the radio. After RADIO is TURN ON then “no service” messages come out. When checking about current configured band where as below:
AT!BAND=?
Index, Name
00, All bands
05, GSM ALL
06, Europe
08, WCDMA ALL
09, LTE ALL
0A, Oceania
I’m from ASIA Region, do in need to add-in ASIA Region as well.
Regards,
Zainul
Zainul,
There is no Asia/APAC setting, it is the same as the European one.
So when you do not have the W_disable line pulled what are the responses to the below commands
at+cpin?
at+creg?
at+cgreg?
at!gstatus?
at+csq
at+cops?
at+cops=?
Hello Matt,
Please find attached for your kind perusal and reference. For information, If using latest firmware level then another errors come out.
Regards,
Zainul
MC7304-01.txt (373 Bytes)
Hello Matt,
Have a good day and sorry to disturb you again. I’ve done firmware update with latest release from sierra for this model MC7304 (Build4467-Approved-7304-EXE) then new below errors:
Mobile Broadband is Off
Laptop wireless switch is off
Please find attached all that related AT commands based on previous errors for your kind perusal and reference. I concerning on how to enable mobile broadband ?
Regards,
Zainul
MC7304-latest01.txt (354 Bytes)
MC7304-latest.txt (940 Bytes)
I can still see in the commands you have sent that the unit is seeing the W_disable line still pulled low.
Hello mlw,
Have a good day and thanks a lot. Actually that problem was resolved by downgraded firmware and un-taped #20 pin as mentioned by someone.
Regards,
Zainul
