Hello gentlemen,
currently I am facing an issue on the MC7304 that is related to a change to a newer Firmware Version.
I used to have 05.05.16.02 but when moving to 05.05.58.00 I start getting Problems during the USB enumeration on Linux Startup which Looks as follows:
(Please note the time steps between the error Messages. This is what annoys me as it prevents the machine from booting quickly.)
[ 28.796881] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[ 28.796927] i915 0000:00:02.0: registered panic notifier
[ 40.344321] usb 1-4.1: device descriptor read/64, error -110
[ 55.536195] usb 1-4.1: device descriptor read/64, error -110
[ 55.728370] usb 1-2.4.3: new full-speed USB device number 6 using xhci_hcd
[ 55.835655] usb 1-2.4.3: New USB device found, idVendor=046d, idProduct=c534
[ 55.835718] usb 1-2.4.3: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 55.835775] usb 1-2.4.3: Product: USB Receiver
[ 55.835811] usb 1-2.4.3: Manufacturer: Logitech
[ 55.852206] hidraw: raw HID events driver (C) Jiri Kosina
[ 55.861858] usbcore: registered new interface driver usbhid
[ 55.861931] usbhid: USB HID core driver
[ 55.866999] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.4/1-2.4.3/1-2.4.3:1.0/0003:046D:C534.0001/input/input2
[ 55.908561] usb 1-4.1: new high-speed USB device number 7 using xhci_hcd
[ 55.920854] hid-generic 0003:046D:C534.0001: input,hidraw0: USB HID v1.11 Keyboard [Logitech USB Receiver] on usb-0000:00:14.0-2.4.3/input0
[ 55.921544] input: Logitech USB Receiver as /devices/pci0000:00/0000:00:14.0/usb1/1-2/1-2.4/1-2.4.3/1-2.4.3:1.1/0003:046D:C534.0002/input/input3
[ 55.977252] hid-generic 0003:046D:C534.0002: input,hiddev0,hidraw1: USB HID v1.11 Mouse [Logitech USB Receiver] on usb-0000:00:14.0-2.4.3/input1
[ 70.996351] usb 1-4.1: device descriptor read/64, error -110
[ 86.188228] usb 1-4.1: device descriptor read/64, error -110
[ 86.364381] usb 1-4.1: new high-speed USB device number 8 using xhci_hcd
[ 91.385627] xhci_hcd 0000:00:14.0: Command completion event does not match command
[ 91.385634] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 96.607020] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 96.811289] usb 1-4.1: device not accepting address 8, error -62
[ 96.883374] usb 1-4.1: new high-speed USB device number 9 using xhci_hcd
[ 101.892586] xhci_hcd 0000:00:14.0: Command completion event does not match command
[ 101.892594] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 107.114065] xhci_hcd 0000:00:14.0: Timeout while waiting for setup device command
[ 107.318265] usb 1-4.1: device not accepting address 9, error -62
[ 107.318386] usb 1-4-port1: unable to enumerate USB device
[ 112.712613] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
Some few more notes:
- It may take up to five minutes until the device finally is ready and usable
- The strange Thing is, that this only appears to happen on Insyde UEFI based machines (Intel and AMD).
- When switching to American Megatrends UEFI or Phoenix BIOS, all seems to work fine.
- What I also like to mention: this only happens during power up of the machines, when rebooting the OS no Problems appear.
- It does not matter if I connect the modem to an EHCI or XHCI port.
- Linux kernel Version is 4.2
- Using Windows, I also see strange behavior in device manager
Has anybody ever faced a similar issue?
Any hint or help is much appreciated!
