root@710-200-9990002:~# dmesg
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Linux version 4.14.78-g8e54a4b719e6 (root@ip-172-31-22-206) (gcc version 6.3.1 20170404 (Linaro GCC 6.3-2017.05)) #1 SMP PREEMPT Tue Nov 15 16:41:09 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: div instructions available: patching division code
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] OF: fdt: Machine model: T29, Vero Hub 3 with i.MX6UL, eMMC & WiFi support
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 131072
[ 0.000000] free_area_init_node: node 0, pgdat 80f9b440, node_mem_map 9fb77000
[ 0.000000] Normal zone: 1152 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 131072 pages, LIFO batch:31
[ 0.000000] percpu: Embedded 16 pages/cpu @9fb4e000 s35468 r8192 d21876 u65536
[ 0.000000] pcpu-alloc: s35468 r8192 d21876 u65536 alloc=16*4096
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 129920
[ 0.000000] Kernel command line: console=ttymxc0,115200 root=/dev/mmcblk1p2 rootwait rw
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 503632K/524288K available (9216K kernel code, 625K rwdata, 3160K rodata, 1024K init, 439K bss, 20656K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xa0800000 - 0xff800000 (1520 MB)
lowmem : 0x80000000 - 0xa0000000 ( 512 MB)
pkmap : 0x7fe00000 - 0x80000000 ( 2 MB)
modules : 0x7f000000 - 0x7fe00000 ( 14 MB)
.text : 0x80008000 - 0x80a00000 (10208 kB)
.init : 0x80e00000 - 0x80f00000 (1024 kB)
.data : 0x80f00000 - 0x80f9c5e0 ( 626 kB)
.bss : 0x80f9e000 - 0x8100bde8 ( 440 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[ 0.000000] Switching to timer-based delay loop, resolution 333ns
[ 0.000019] sched_clock: 32 bits at 3000kHz, resolution 333ns, wraps every 715827882841ns
[ 0.000057] clocksource: mxc_timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 637086815595 ns
[ 0.003413] Console: colour dummy device 80x30
[ 0.003469] Calibrating delay loop (skipped), value calculated using timer frequency.. 6.00 BogoMIPS (lpj=30000)
[ 0.003504] pid_max: default: 32768 minimum: 301
[ 0.003885] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.003915] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.005544] CPU: Testing write buffer coherency: ok
[ 0.006288] /cpus/cpu@0 missing clock-frequency property
[ 0.006327] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.040592] Setting up static identity map for 0x80100000 - 0x80100060
[ 0.060573] Hierarchical SRCU implementation.
[ 0.100795] smp: Bringing up secondary CPUs ...
[ 0.100826] smp: Brought up 1 node, 1 CPU
[ 0.100845] SMP: Total of 1 processors activated (6.00 BogoMIPS).
[ 0.100861] CPU: All CPU(s) started in SVC mode.
[ 0.102653] devtmpfs: initialized
[ 0.119557] random: get_random_u32 called from bucket_table_alloc+0xf8/0x248 with crng_init=0
[ 0.121321] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.121962] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.122015] futex hash table entries: 256 (order: 2, 16384 bytes)
[ 0.122383] pinctrl core: initialized pinctrl subsystem
[ 0.124551] NET: Registered protocol family 16
[ 0.125289] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.131249] cpuidle: using governor menu
[ 0.146054] vdd3p0: supplied by regulator-dummy
[ 0.147342] cpu: supplied by regulator-dummy
[ 0.148609] vddsoc: supplied by regulator-dummy
[ 0.176983] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.177011] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.179576] imx6ul-pinctrl 20e0000.iomuxc: initialized IMX pinctrl driver
[ 0.180454] imx6ul-pinctrl 2290000.iomuxc-snvs: initialized IMX pinctrl driver
[ 0.256741] vgaarb: loaded
[ 0.258575] SCSI subsystem initialized
[ 0.258710] libata version 3.00 loaded.
[ 0.259247] usbcore: registered new interface driver usbfs
[ 0.259378] usbcore: registered new interface driver hub
[ 0.259638] usbcore: registered new device driver usb
[ 0.261800] i2c i2c-0: IMX I2C adapter registered
[ 0.261846] i2c i2c-0: can't use DMA, using PIO instead.
[ 0.264085] i2c i2c-1: IMX I2C adapter registered
[ 0.264126] i2c i2c-1: can't use DMA, using PIO instead.
[ 0.265287] Linux video capture interface: v2.00
[ 0.265469] pps_core: LinuxPPS API ver. 1 registered
[ 0.265488] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.265546] PTP clock support registered
[ 0.268293] MIPI CSI2 driver module loaded
[ 0.269362] imx rpmsg driver is registered.
[ 0.269802] Advanced Linux Sound Architecture Driver Initialized.
[ 0.271722] Bluetooth: Core ver 2.22
[ 0.271851] NET: Registered protocol family 31
[ 0.271870] Bluetooth: HCI device and connection manager initialized
[ 0.271907] Bluetooth: HCI socket layer initialized
[ 0.271932] Bluetooth: L2CAP socket layer initialized
[ 0.272015] Bluetooth: SCO socket layer initialized
[ 0.293214] clocksource: Switched to clocksource mxc_timer1
[ 0.293621] VFS: Disk quotas dquot_6.6.0
[ 0.293804] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.316398] NET: Registered protocol family 2
[ 0.317891] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.318027] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.318183] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.318409] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.318479] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.318882] NET: Registered protocol family 1
[ 0.340216] RPC: Registered named UNIX socket transport module.
[ 0.340240] RPC: Registered udp transport module.
[ 0.340254] RPC: Registered tcp transport module.
[ 0.340266] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.340299] PCI: CLS 0 bytes, default 64
[ 0.346037] Bus freq driver module loaded
[ 0.348876] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[ 0.372924] NFS: Registering the id_resolver key type
[ 0.372993] Key type id_resolver registered
[ 0.373008] Key type id_legacy registered
[ 0.373115] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.374483] fuse init (API version 7.26)
[ 0.407991] io scheduler noop registered
[ 0.408019] io scheduler deadline registered
[ 0.408432] io scheduler cfq registered (default)
[ 0.408459] io scheduler mq-deadline registered
[ 0.408476] io scheduler kyber registered
[ 0.409855] imx-weim 21b8000.weim: Driver registered.
[ 0.418492] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.429436] mxs-dma 1804000.dma-apbh: initialized
[ 0.435593] 2020000.serial: ttymxc0 at MMIO 0x2020000 (irq = 18, base_baud = 5000000) is a IMX
[ 0.961080] console [ttymxc0] enabled
[ 0.965719] 21e8000.serial: ttymxc1 at MMIO 0x21e8000 (irq = 64, base_baud = 5000000) is a IMX
[ 0.974792] 21ec000.serial: ttymxc2 at MMIO 0x21ec000 (irq = 65, base_baud = 5000000) is a IMX
[ 0.984062] 21f4000.serial: ttymxc4 at MMIO 0x21f4000 (irq = 66, base_baud = 5000000) is a IMX
[ 0.993163] 21fc000.serial: ttymxc5 at MMIO 0x21fc000 (irq = 67, base_baud = 5000000) is a IMX
[ 1.002338] 2288000.serial: ttymxc7 at MMIO 0x2288000 (irq = 72, base_baud = 5000000) is a IMX
[ 1.048227] imx-rng 2284000.rngb: iMX RNG Registered.
[ 1.053767] [drm] Initialized vivante 1.0.0 20120216 for platform:Vivante GCCore on minor 0
[ 1.060873] [drm] Initialized vivante 1.0.0 20120216 on minor 0
[ 1.093894] brd: module loaded
[ 1.115894] loop: module loaded
[ 1.127172] libphy: Fixed MDIO Bus: probed
[ 1.130909] CAN device driver interface
[ 1.137019] fec 2188000.ethernet: 2188000.ethernet supply phy not found, using dummy regulator
[ 1.264274] pps pps0: new PPS source ptp0
[ 1.268337] libphy: fec_enet_mii_bus: probed
[ 1.284810] fec 2188000.ethernet eth0: registered PHC device 0
[ 1.290356] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.295855] ehci-pci: EHCI PCI platform driver
[ 1.299193] ehci-mxc: Freescale On-Chip EHCI Host driver
[ 1.303921] usbcore: registered new interface driver usb-storage
[ 1.308779] usbcore: registered new interface driver usb_ehset_test
[ 1.316892] usbmisc_imx 2184800.usbmisc: 2184800.usbmisc supply vbus-wakeup not found, using dummy regulator
[ 1.328163] imx_usb 2184000.usb: 2184000.usb supply vbus not found, using dummy regulator
[ 1.339113] ci_hdrc ci_hdrc.0: EHCI Host Controller
[ 1.342801] ci_hdrc ci_hdrc.0: new USB bus registered, assigned bus number 1
[ 1.373308] ci_hdrc ci_hdrc.0: USB 2.0 started, EHCI 1.00
[ 1.379502] hub 1-0:1.0: USB hub found
[ 1.382139] hub 1-0:1.0: 1 port detected
[ 1.397656] imx_usb 2184200.usb: 2184200.usb supply vbus not found, using dummy regulator
[ 1.408752] ci_hdrc ci_hdrc.1: EHCI Host Controller
[ 1.412436] ci_hdrc ci_hdrc.1: new USB bus registered, assigned bus number 2
[ 1.443302] ci_hdrc ci_hdrc.1: USB 2.0 started, EHCI 1.00
[ 1.449518] hub 2-0:1.0: USB hub found
[ 1.452149] hub 2-0:1.0: 1 port detected
[ 1.470279] input: 20cc000.snvs:snvs-powerkey as /devices/soc0/soc/2000000.aips-bus/20cc000.snvs/20cc000.snvs:snvs-powerkey/input/input0
[ 1.484089] edt_ft5x06 1-0038: touchscreen probe failed
[ 1.494737] snvs_rtc 20cc000.snvs:snvs-rtc-lp: rtc core: registered 20cc000.snvs:snvs-rtc-lp as rtc0
[ 1.503080] i2c /dev entries driver
[ 1.510237] pxp-v4l2 pxp_v4l2: initialized
[ 1.517880] imx2-wdt 20bc000.wdog: timeout 60 sec (nowayout=0)
[ 1.522927] Bluetooth: HCI UART driver ver 2.3
[ 1.526253] Bluetooth: HCI UART protocol H4 registered
[ 1.530315] Bluetooth: HCI UART protocol LL registered
[ 1.536262] sdhci: Secure Digital Host Controller Interface driver
[ 1.541183] sdhci: Copyright(c) Pierre Ossman
[ 1.544386] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.613383] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 1.693380] mmc1: SDHCI controller on 2194000.usdhc [2194000.usdhc] using ADMA
[ 1.737133] usbcore: registered new interface driver usbhid
[ 1.741595] usbhid: USB HID core driver
[ 1.747870] Error: Driver 'mpl3115' is already registered, aborting...
[ 1.759570] wm8731 1-001a: 1-001a supply AVDD not found, using dummy regulator
[ 1.766469] wm8731 1-001a: 1-001a supply HPVDD not found, using dummy regulator
[ 1.772801] wm8731 1-001a: 1-001a supply DCVDD not found, using dummy regulator
[ 1.780338] wm8731 1-001a: 1-001a supply DBVDD not found, using dummy regulator
[ 1.787803] wm8731 1-001a: Failed to issue reset: -6
[ 1.818019] random: fast init done
[ 1.833334] usb 2-1: new high-speed USB device number 2 using ci_hdrc
[ 1.838853] mmc1: new DDR MMC card at address 0001
[ 1.852299] mmcblk1: mmc1:0001 Q2J55L 7.09 GiB
[ 1.856090] NET: Registered protocol family 26
[ 1.857517] NET: Registered protocol family 10
[ 1.867003] mmcblk1boot0: mmc1:0001 Q2J55L partition 1 16.0 MiB
[ 1.873511] mmcblk1boot1: mmc1:0001 Q2J55L partition 2 16.0 MiB
[ 1.879451] Segment Routing with IPv6
[ 1.879614] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[ 1.881138] NET: Registered protocol family 17
[ 1.881178] can: controller area network core (rev 20170425 abi 9)
[ 1.881381] NET: Registered protocol family 29
[ 1.881398] can: raw protocol (rev 20170425)
[ 1.881408] can: broadcast manager protocol (rev 20170425 t)
[ 1.881430] can: netlink gateway (rev 20170425) max_hops=1
[ 1.887072] Bluetooth: RFCOMM TTY layer initialized
[ 1.887116] Bluetooth: RFCOMM socket layer initialized
[ 1.887180] Bluetooth: RFCOMM ver 1.11
[ 1.887214] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 1.887221] Bluetooth: BNEP filters: protocol multicast
[ 1.887262] Bluetooth: BNEP socket layer initialized
[ 1.887274] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 1.887295] Bluetooth: HIDP socket layer initialized
[ 1.887437] 8021q: 802.1Q VLAN Support v1.8
[ 1.887545] Key type dns_resolver registered
[ 2.000919] mmcblk1rpmb: mmc1:0001 Q2J55L partition 3 4.00 MiB
[ 2.020004] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 2.029381] (NULL device *): hwmon_device_register() is deprecated. Please convert the driver to use hwmon_device_register_with_info().
[ 2.041053] imx_thermal 2000000.aips-bus:tempmon: Industrial CPU temperature grade - max:105C critical:100C passive:95C
[ 2.054508] usb 2-1: config 1 has an invalid interface number: 8 but max is 3
[ 2.060415] usb 2-1: config 1 has no interface number 1
[ 2.065148] mmcblk1: p1 p2 p3 p4 < p5 p6 >
[ 2.069215] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 2.084419] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 2.096398] input: keys as /devices/soc0/keys/input/input2
[ 2.104472] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 2.112628] snvs_rtc 20cc000.snvs:snvs-rtc-lp: setting system clock to 2024-01-23 17:57:15 UTC (1706032635)
[ 2.122785] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 2.131777] VSD_3V3: disabling
[ 2.133809] gpio_dvfs: disabling
[ 2.135756] ALSA device list:
[ 2.137455] No soundcards found.
[ 2.176898] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.183968] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.197172] devtmpfs: mounted
[ 2.200408] Freeing unused kernel memory: 1024K
[ 2.693925] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 2.731205] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.752591] systemd[1]: Detected architecture arm.
[ 2.795770] systemd[1]: Set hostname to <710-200-9990002>.
[ 3.757616] systemd[1]: File /lib/systemd/system/systemd-journald.service:12 configures an IP firewall (IPAddressDeny=any), but the local system does not support BPF/cgroup based firewalling.
[ 3.773761] systemd[1]: Proceeding WITHOUT firewalling in effect! (This warning is only shown for the first loaded unit using IP firewalling.)
[ 4.336240] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.360150] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.367000] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 4.403913] random: systemd: uninitialized urandom read (16 bytes read)
[ 4.410585] systemd[1]: Listening on udev Kernel Socket.
[ 4.496341] systemd[1]: Condition check resulted in Journal Audit Socket being skipped.
[ 4.510297] systemd[1]: Created slice system-getty.slice.
[ 4.550824] systemd[1]: Created slice User and Session Slice.
[ 6.495808] Adding 262140k swap on /swapfile. Priority:-2 extents:3 across:999420k SS
[ 7.174486] systemd-journald[125]: Received request to flush runtime journal from PID 1
[ 9.852956] pxp-v4l2 pxp_v4l2: failed to call pxp_set_fbinfo
[ 10.512707] imx-sdma 20ec000.sdma: loaded firmware 3.3
[ 10.547255] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 11.020080] usbcore: registered new interface driver usbserial
[ 11.061991] usbcore: registered new interface driver usbserial_generic
[ 11.097068] usbcore: registered new interface driver cdc_wdm
[ 11.118639] usbserial: USB Serial support registered for generic
[ 15.297536] EXT4-fs (mmcblk1p6): mounted filesystem with ordered data mode. Opts: (null)
[ 17.392939] random: crng init done
[ 17.406343] random: 7 urandom warning(s) missed due to ratelimiting
[ 18.493436] mmc0: SDHCI controller on 2190000.usdhc [2190000.usdhc] using ADMA
[ 18.507537] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 18.553574] mmc0: queuing unknown CIS tuple 0x80 (2 bytes)
[ 18.585164] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 18.602100] mmc0: queuing unknown CIS tuple 0x80 (3 bytes)
[ 18.628300] mmc0: queuing unknown CIS tuple 0x80 (7 bytes)
[ 18.831426] mmc0: new high speed SDIO card at address 0001
[ 18.862206] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 18.898808] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdio.bin for chip 0x00a9a6(43430) rev 0x000001
[ 18.927435] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 19.106148] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Sep 11 2018 09:22:09 version 7.45.98.65 (r707797 CY) FWID 01-b54727f
[ 1050.811997] usb 2-1: USB disconnect, device number 2
[ 1055.053398] usb 2-1: new high-speed USB device number 3 using ci_hdrc
[ 1055.264782] usb 2-1: config 1 has an invalid interface number: 8 but max is 3
[ 1055.270648] usb 2-1: config 1 has no interface number 1
[ 1055.302277] pwm-backlight backlight: backlight supply power not found, using dummy regulator
