I have a problem with my MC7304. I was running on Debian and Voyage linux and I notice that the device disconnects approximately every 1000s.
I can’t tell if this disconnect is initiated by the device or the OS.
(It may not be related but I also get an error when I connect (cu) to the device. It works every second connection and fails with “cu: write: Input/output error” on the subsequent attempt.)
Appreciate any help.
Oct 11 09:53:43 localhost vmunix: [ 1359.502189] usb 5-1: USB disconnect, device number 3
Oct 11 09:53:43 localhost vmunix: [ 1359.507976] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Oct 11 09:53:43 localhost vmunix: [ 1359.516117] option 5-1:1.0: device disconnected
Oct 11 09:53:43 localhost vmunix: [ 1359.521174] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Oct 11 09:53:43 localhost vmunix: [ 1359.529316] option 5-1:1.4: device disconnected
Oct 11 09:53:57 localhost vmunix: [ 1373.384054] usb 5-1: new full-speed USB device number 4 using ohci-pci
Oct 11 09:53:57 localhost vmunix: [ 1373.532636] usb 5-1: config 1 has an invalid interface number: 4 but max is 1
Oct 11 09:53:57 localhost vmunix: [ 1373.539867] usb 5-1: config 1 has no interface number 1
Oct 11 09:53:57 localhost vmunix: [ 1373.551626] usb 5-1: New USB device found, idVendor=1199, idProduct=68c0
Oct 11 09:53:57 localhost vmunix: [ 1373.558356] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 11 09:53:57 localhost vmunix: [ 1373.565505] usb 5-1: Product: MC7304
Oct 11 09:53:57 localhost vmunix: [ 1373.569102] usb 5-1: Manufacturer: Sierra Wireless, Incorporated
Oct 11 09:53:57 localhost vmunix: [ 1373.575123] usb 5-1: SerialNumber: 0123456789ABCDEF
Oct 11 09:53:57 localhost vmunix: [ 1373.582268] option 5-1:1.0: GSM modem (1-port) converter detected
Oct 11 09:53:57 localhost vmunix: [ 1373.588841] usb 5-1: GSM modem (1-port) converter now attached to ttyUSB0
Oct 11 09:53:57 localhost vmunix: [ 1373.595951] option 5-1:1.4: GSM modem (1-port) converter detected
Oct 11 09:53:57 localhost vmunix: [ 1373.602300] usb 5-1: GSM modem (1-port) converter now attached to ttyUSB1
Oct 11 10:10:33 localhost vmunix: [ 2369.763368] usb 5-1: USB disconnect, device number 4
Oct 11 10:10:33 localhost vmunix: [ 2369.769064] option1 ttyUSB0: GSM modem (1-port) converter now disconnected from ttyUSB0
Oct 11 10:10:33 localhost vmunix: [ 2369.777204] option 5-1:1.0: device disconnected
Oct 11 10:10:33 localhost vmunix: [ 2369.782249] option1 ttyUSB1: GSM modem (1-port) converter now disconnected from ttyUSB1
Oct 11 10:10:33 localhost vmunix: [ 2369.790421] option 5-1:1.4: device disconnected
Oct 11 10:10:47 localhost vmunix: [ 2383.698185] usb 5-1: new full-speed USB device number 5 using ohci-pci
Oct 11 10:10:47 localhost vmunix: [ 2383.847966] usb 5-1: config 1 has an invalid interface number: 4 but max is 1
Oct 11 10:10:47 localhost vmunix: [ 2383.855217] usb 5-1: config 1 has no interface number 1
Oct 11 10:10:47 localhost vmunix: [ 2383.866952] usb 5-1: New USB device found, idVendor=1199, idProduct=68c0
Oct 11 10:10:47 localhost vmunix: [ 2383.873685] usb 5-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Oct 11 10:10:47 localhost vmunix: [ 2383.880856] usb 5-1: Product: MC7304
Oct 11 10:10:47 localhost vmunix: [ 2383.884458] usb 5-1: Manufacturer: Sierra Wireless, Incorporated
Oct 11 10:10:47 localhost vmunix: [ 2383.890489] usb 5-1: SerialNumber: 0123456789ABCDEF
Oct 11 10:10:47 localhost vmunix: [ 2383.897350] option 5-1:1.0: GSM modem (1-port) converter detected
Oct 11 10:10:47 localhost vmunix: [ 2383.904044] usb 5-1: GSM modem (1-port) converter now attached to ttyUSB0
Oct 11 10:10:47 localhost vmunix: [ 2383.911190] option 5-1:1.4: GSM modem (1-port) converter detected
Oct 11 10:10:47 localhost vmunix: [ 2383.917517] usb 5-1: GSM modem (1-port) converter now attached to ttyUSB1
