MC7304 problem with LTE Tx test mode
Hello Guys,
I am trying to test a MC7304 modem and I just discover that when I try to configure LTE BAND by using AT!DASBAND command, I received “0” as an answer from the modem , this behavior is not normal compared with other testing mode (like wcdma or gsm). For my understanding, answer must be the band itself after you press “enter” twice and not 0 , could you please help me to understand if I am missing something?
Thank you in advance.
WCDMA TX 2100 configuration:
AT+CFUN=1
AT!ENTERCND=“A710”
AT!DAFTMACT
290300
AT!DASBAND=12 <— WCDMA BAND
12 <— MODEM ANSWER
AT!DASCHAN=661
661
LTE TX 2100 configuration:
AT+CFUN=1
AT!ENTERCND=“A710”
AT!DAFTMACT
290300
AT!DASBAND=34 <------ LTE BAND
0 <------ MODEM ANSWER
AT!DALSTXBW=5
AT!DALSRXBW=5
AT!DASCHAN=18300
18176
hi,
It is recommended to do a soft reset by giving AT!RESET after AT!DAFTMDEACT to ensure modem exiting FTM mode reliably.
So between two test sequence , be sure to run AT!RESET to reset properly the device after the AT!DAFTMDEACT
thanks,
Alex
Hi Alex,
“It is recommended to do a soft reset by giving AT!RESET after AT!DAFTMDEACT to ensure modem exiting FTM mode reliably.
So between two test sequence , be sure to run AT!RESET to reset properly the device after the AT!DAFTMDEACT”
I have the same issue but I with AT!DAFTMACT, as per the original question.
Please share if AT!DAFTMACT is used instead of AT!DAFTMDEACT.
