We are trying to integrate an equipment using MC7304 as a Modem.
We can confirm that it can work and attach with the local public networks using LTE (i.e., Telstra or Vodafone).
When using it on a private 2G network, we can confirm it sees the base station but it’s not successfully registering.
Have tried upgrading the modem’s firmware with the latest Generic version (instead of Telstra), it can see the 2G network now when issuing AT+COPS=? command but still unsuccessful in GPRS / PS attaching.
Based on AT!GSTATUS?, the following is the result:
!GSTATUS:
Current Time: 97 Temperature: 35
Bootup Time: 5 Mode: ONLINE
System mode: GSM PS state: Not attached
GSM band: DCS1800
GSM channel: 872
GMM (PS) state: DEREGISTERED ATT NEEDED
MM (CS) state: IDLE UPDATE NEEDED
I get a CME Error 30: which is “No network service”
This is confusing as I can confirm that the SIM card would work on another device using another Modem (HL7692). And When I issue AT+COPS=? it can see the network as well.
Yes it can come back with this if it has been rejected by the network as from its point of view it does not have a network to connect to but thats down to the language used in the spec’s.
Does that mean that the modem isn’t compatible with the network or can I take this with the network provider and get support and understanding on why it’s being refused. The engineers on that side can verbally confirmed that they don’t have IMEI blocking but this results is telling me otherwise.
Does Sierra Wireless have a protocol tracing software tool so I can prove it’s the network causing the rejection?
Assuming you can see the 2G network its probably going to be a SIM rights issue, you have mentioned Telstra, there is no 2G in Australia any more so I am surprised.
Can you post the actual responses from the unit to the below?
ati
at!priid?
at+cimi
at+cops?
at+cops=?
at+cops=1,2,“xxxxx”,0
Thanks. How do I confirm if it’s a SIM rights issue? That would be weird as the SIM works on another equipment with a HL7692 Modem. The 2G network is a private telco used for GSM-R so don’t be surprised, you would know how the rail industry takes forever to move and transition to the latest and greatest.
