MC7304 & "Link layer protocol"
Hello All.
I’m using MC7304 under Linux-machine.
Network interface (wwan) doesn’t work properly unless I change a “Link laeyr protocol”
from “raw-ip” to “802-3”.
I do It through QMI-interface
qmicli -d /dev/cdc-wdm0 --wda-set-data-format=‘802-3’
I am extremely interested to make it through some AT-command.
Tell me please that if anybody knows.
Thank you,
Mikhail
hi,
I don’t think there is any AT command to change this… Normally it should work with ‘raw-ip’. what is the issue you are facing?
-Alex
Hi
Why not, Alex?
The command
send some configure setting to MC7304.
And after that command the module starts to “understand” packets coming from
the driver (qmi_wwan).
Another words, the module and the driver both are using the same frame format (Ethernet-like).
Mikhail
