MC7304 force to use ipv4 only
How do I change MC7304 PDP type: ‘ipv4-or-ipv6’ to ‘ipv4’ only from qmicli command line?
Tried this but no luck… got error no option!
qmicli -p -d /dev/cdc-wdm0 --wds-modify-profile=3gpp,1,pdp-type=‘ipv4’
Thanks!
Are you using MC7430 instead of MC7403?
does this help?
my bad it’s MC7304 instead of MC7403… whats option should I use? didn’t work with below
have you tried this?
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wds-start-network="ip-type=4,apn=data.tre.se" --client-no-release-cid
No luck nothing changed
how about this?
qmicli -d /dev/cdc-wdm0 --wds-modify-profile=“3gpp,1,apn=internet,pdp-type=IPV4V6”
OR
qmicli -d /dev/cdc-wdm0 --wds-modify-profile=“3gpp,1,apn=internet,pdp-type=IP”
I got option error, looks like didn’t work with “–wds-modify-profile” but work fine if “–wds-get-profile-list=3gpp”
I don’t have MC7304, but I don’t see problem with MC7430
owner@ubuntu:~$ sudo qmicli -d /dev/cdc-wdm0 --wds-modify-profile="3gpp,1,apn=internet,pdp-type=IP"
Profile successfully modified.
owner@ubuntu:~$ sudo qmicli --version
qmicli 1.22.0
Copyright (C) 2012-2019 Aleksander Morgado
License GPLv2+: GNU GPL version 2 or later <http://gnu.org/licenses/gpl-2.0.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
at+cgdcont?
+CGDCONT: 1,"IP","internet","0.0.0.0",0,0,0,0
ati3
Model: MC7430
Revision: SWI9X30C_02.33.03.00 r8209 CARMD-EV-FRMWR2 2019/08/28 20:59:30
MEID: 35907406012345
IMEI: 359074060012345
IMEI SV: 20
FSN: LU626300112345
+GCAP: +CGSM
Yeah, I don’t have problem with MC7455 as well… may have to figure out howto run AT command line
Many thanks for your help jyijyi
@jyijyi - any thoughts? Thanks!
root ~# qmicli -p -d /dev/cdc-wdm0 --wds-modify-profile=3gpp,1,pdp_type=IPV4
error: Unknown option --wds-modify-profile=3gpp,1,pdp_type=IPV4
root ~# qmicli -p -d /dev/cdc-wdm0 --wds-modify-profile=3gpp,1,apn=‘mmsbouygtel.com’
error: Unknown option --wds-modify-profile=3gpp,1,apn=mmsbouygtel.com
root ~# qmicli --version
qmicli 1.12.6
Copyright (C) 2015 Aleksander Morgado
License GPLv2+: GNU GPL version 2 or later GNU General Public License v2.0 - GNU Project - Free Software Foundation
root ~# qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wds-start-network=“ip-type=4,apn=test” --client-no-release-cid
error: couldn’t start network: QMI protocol error (14): ‘CallFailed’
call end reason (12): (NULL)
verbose call end reason (2,201): [internal] error
[/dev/cdc-wdm0] Client ID not released:
Service: ‘wds’
CID: ‘17’
root ~# qmicli -d /dev/cdc-wdm0 --wds-get-profile-list=3gpp
Profile list retrieved:
[1] 3gpp - profile1
APN: ‘ip-type=4’
Auth: ‘none’
Does it work with mc74xx with same sim card?
Have you checked AT!GSTATUS? to see if module registers network before starting the data establishment?
Is it really true that “test” is the APN of your sim card?
Yes , it works with MC7455, changed apn=Broadband (ATT SIM CARD) didn’t work as well…
qmicli --device=/dev/cdc-wdm0 --device-open-proxy --wds-start-network=“ip-type=4,apn=data.tre.se” --client-no-release-cid
didnot change pdp_type but apn… other option that I can use for qmicli… unable to use AT cmd
qmicli 1.12.6 limitation?
what do you mean by “cannot use AT command”?
Do you have /dev/ttyUSB2 port?
Is that you must use qmicli for data establishment?
You can see other user’s qmicli log on MC7354:
Nope, not me… I simply want to use qmicli commandline to change PDP type: ‘ipv4-or-ipv6’ to PDP type: ‘ipv4’ on MC7304, if possible
[1] 3gpp -
APN: ‘mobiledata’
Auth: 'none
if I can find /dev/ttyUSB2 port… can you please help me with howto to change to ipv4?
you can use AT+CGDCONT=1,“IP”,“mobiledata”
how do I run it from linux cmdlines AT+CGDCONT=1,“IP”,“mobiledata”
In Ubuntu PC, I used minicom to open the port /dev/ttyUSB2 and then type the AT command
