logging IP More Details
Hello, While using the ALEOS V4228_4.0.10.001 Jul 21 2011 in the older RavenX’s I was able to observe Logging such as this:
18:37:04 IP: rcv Src 128.95.26.11 Dst 166.140.139.258 proto 6 inIF 1 Ports Src 33824 Dst 12345
18:37:04 IP: Length 40, DNF 1, fragment 0, frag offset 4000
18:37:04 IP: out_if: 1 msg for Aleos port 12345 Forward 0 Oif 1
18:37:04 IP: for Aleos, add S port 33824, D port 12345
Date: 12/14/2014
18:37:05 IP: snd Src 166.140.139.258 Dst 128.95.16.11 proto 6 sp 12345 dp 33824
18:37:05 IP: in PF table: 0 using Src_ip 166.140.139.238 -Tx
18:37:05 IP: rcv Src 128.95.26.11 Dst 166.140.139.258 proto 6 inIF 1 Ports Src 33824 Dst 12345
18:37:05 IP: Length 40, DNF 1, fragment 0, frag offset 4000
18:37:05 IP: out_if: 1 msg for Aleos port 12345 Forward 0 Oif 1
18:37:05 IP: for Aleos, add S port 33824, D port 12345
This is with IP turned onto “more details”
With ALEOS vs 4.3.3b.015, I’m not able to observe this simple exchange of packets to and fro our import machine and Cell modem.
Is there a way that I can observe this detailed list on the logs with the newer vs of ALEOS?
Logging in the newer modems (GX,LS,ES) can be found by logging into AceManager clicking on Admin Tab à Log . Please be aware that the newer modems are built with different platform than the Raven X modems and thus the logs will appear different.
thanks,
Rex
