Hi everybody,
I tried to get the SDK: swi-fx30-catm_3.0.0 installed.
No luck, the package always crash with exception:
leaf.core.error.LeafException: Error during install step for wp77-toolchain_SWI9X06Y_02.36.07.00-linux64 (command returned 1)
ERROR:
Profile provisioning interrupted
CAUSED BY:
See below for extensive log:
Any idea what is wrong there ?
Note: The package swi-fx30-catm_2.0.0 and swi-fx30-catm_1.0.0 produce similar error.
Only package I found to be OK for me: swi-wp77_1.0.0
BR. Damien
user@user-VirtualBox:~/Development/Legato/Workspace$ leaf profile sync
[DEBUG] Load leaf.plugins.leaf_plugins.setup from /usr/share/leaf/packages/leaf-plugins_1.0/setup.py
[DEBUG] Load leaf.plugins.leaf_plugins.update from /usr/share/leaf/packages/leaf-plugins_1.0/update.py
[DEBUG] Load leaf.plugins.leaf_plugins.shell from /usr/share/leaf/packages/leaf-plugins_1.0/shell.py
[DEBUG] Load leaf.plugins.leaf_plugins.completion from /usr/share/leaf/packages/leaf-plugins_1.0/completion.py
[DEBUG] Load leaf.plugins.leaf_plugins.version from /usr/share/leaf/packages/leaf-plugins_1.0/version.py
[DEBUG] Load leaf.plugins.swi_getsrc.getsrc from /usr/share/leaf/packages/swi-getsrc_1.1.190524/getsrc.py
[DEBUG] Load leaf.plugins.swi_leaf_legacy.feature from /usr/share/leaf/packages/swi-leaf-legacy_1.0.190429/feature.py
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_legato from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_legato.commands from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/commands.py
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_legato.swi from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/swi
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lximage from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lximage.commands from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/commands.py
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lximage.swi from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/swi
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lxtoolchain from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lxtoolchain.commands from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/commands.py
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_lxtoolchain.swi from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/swi
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_sdk from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_sdk.commands from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/commands.py
[DEBUG] Load leaf.plugins.swi_sdk_builder.build_sdk.swi from /usr/share/leaf/packages/swi-sdk-builder_4.3.191113/plugins/swi
Profile is out of sync
Packages to install: wp77-toolchain_SWI9X06Y_02.36.07.00-linux64, wp77-modem-image_14.1, fx30-catm-legato-image_19.11.5, fx30-catm-linux-image_R14.1.1.002, fx30-catm-image_3.0.0, swi-legato_1.4.191225, swi-vscode-support_200624, swi-fx30-catm_3.0.0
Total size: 445.6 MB
Do you want to continue? (Y/n)
Y
Run sync steps for swi-aptdeps-image_1.0
Run sync steps for swi-aptdeps-toolchain_1.0
Run sync steps for swi-license_1.2
Run sync steps for swi-verify-aptdeps_1.7.210909
Checking required apt packages.>> Checking libssl-dev
.>> Checking swicwe
.>> Checking swiflash
It is recommended to have the latest version of swiflash swicwe
sudo apt-get update && sudo apt-get install --upgrade -y swiflash swicwe
Do you want to execute this command (Y/n)? Y
[sudo] password for user:
Hit:1 fr.archive.ubuntu.com impish InRelease
Hit:2 fr.archive.ubuntu.com impish-updates InRelease
Hit:3 fr.archive.ubuntu.com impish-backports InRelease
Hit:4 Index of /ubuntu impish-security InRelease
Hit:5 https://downloads.sierrawireless.com/tools/debian release/ InRelease
Reading package lists… Done
Building dependency tree… Done
Reading state information… Done
swicwe is already the newest version (1.27).
swiflash is already the newest version (5.2).
0 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
All system dependencies are OK
Run sync steps for swi-verify-license_1.4.190813
License already accepted: sierra-v1
Downloading 8 package(s)
[1/8] Installing wp77-toolchain_SWI9X06Y_02.36.07.00-linux64
Run install steps for wp77-toolchain_SWI9X06Y_02.36.07.00-linux64
Configuring the toolchain for your environment, this may take a few minutes…
Error during installation: Error during install step for wp77-toolchain_SWI9X06Y_02.36.07.00-linux64 (command returned 1)
Traceback (most recent call last):
File “/usr/lib/python3/dist-packages/leaf/api/packages.py”, line 138, in __extract_artifact
self.__execute_steps(out.identifier, ipmap, StepExecutor.install, env=env)
File “/usr/lib/python3/dist-packages/leaf/api/packages.py”, line 326, in __execute_steps
se_func(se)
File “/usr/lib/python3/dist-packages/leaf/model/steps.py”, line 66, in install
self.__run_steps(self.__package.jsonget(JsonConstants.INSTALL), label="install")
File “/usr/lib/python3/dist-packages/leaf/model/steps.py”, line 80, in __run_steps
self.__execute(step, label)
File “/usr/lib/python3/dist-packages/leaf/model/steps.py”, line 100, in __execute
raise LeafException("Error during {label} step for {ip.identifier} (command returned {rc})".format(label=label, ip=self.__package, rc=rc))
ERROR:
CAUSED BY:
HINT:
try leaf profile sync to resume
File “/usr/lib/python3/dist-packages/leaf/api/workspace.py”, line 273, in provision_profile
self.install_packages(profile.packages, env=self.build_pf_environment(profile))
File “/usr/lib/python3/dist-packages/leaf/api/packages.py”, line 269, in install_packages
ip = self.__extract_artifact(la, env, ipmap, keep_folder_on_error=keep_folder_on_error)
File “/usr/lib/python3/dist-packages/leaf/api/packages.py”, line 150, in __extract_artifact
raise e
se_func(se)
During handling of the above exception, another exception occurred:
File “/usr/lib/python3/dist-packages/leaf/main.py”, line 59, in run_leaf
out = args.handler.safe_execute(args, uargs)
File “/usr/lib/python3/dist-packages/leaf/cli/base.py”, line 103, in safe_execute
return self.execute(args, uargs)
File “/usr/lib/python3/dist-packages/leaf/cli/commands/profile.py”, line 137, in execute
wm.provision_profile(profile)
File “/usr/lib/python3/dist-packages/leaf/api/workspace.py”, line 275, in provision_profile
raise ProfileProvisioningException(e)
leaf.core.error.ProfileProvisioningException: Profile provisioning interrupted
