KHTTPS_ERROR: 0, 5 on HL6528G
I’m trying to do post with HL6528G. I get the correct answer 60% of the time, the other time I receive KHTTPS_ERROR: 0, 5
which means “HTTP connection error due to internal trouble”. The posts are made every 30 s and the signal quality is always good.
I tried to execute the post with the following commands:
  1. AT+KHTTPSHEADER=0
    the answer is CONNECT
  2. then I send the following data:
    Content-Type: application/json
    token: 20736A100633STL
    Content-Length: 123
    –EOF–Pattern–
    the answer is:
  3. AT+KHTTPSPOST=0,“https://elb-esocialbike-demo-2118703486.eu-west-1.elb.amazonaws.com/eBikeRESTDiagnostic20/rest/tracker/updateStatus”
  4. then I send the post message followed by --EOF–Pattern–
the answer can be correct or KHTTPS_ERROR: 0, 5.
Could you explain me why I get the internal trouble error randomically?
could you please share your complete AT command? Also we have to analyse spy trace to know the exact cause of this internal error.
-Alex
This is the complete list of the AT commands and response for the HTTP post we made.
------------>A good one:
AT+KHTTPCFG=0, “46.51.176.136”,9999
+KHTTPCFG: 0
AT+KHTTPHEADER=0
CONNECT
token: STLTRK001
Content-Length: 43
–EOF–Pattern–
AT+KHTTPPOST=0,"/eBikeRESTDiagnostic20/rest/tracker/updateStatus"
CONNECT
{“ts”:“1451692877”,“sn”:“18,1”,“alarm”:“1”}
–EOF–Pattern–
HTTP/1.1 200 OK
Server: nginx/1.6.3
Date: Thu, 01 Sep 2016 12:31:11 GMT
Content-Type: text/plain;charset=utf-8
Content-Length: 1
------------>A bad one:
+KHTTPCFG: 0
AT+KHTTPHEADER=0
CONNECT
token: STLTRK001
Content-Length: 43
–EOF–Pattern–
+KHTTP_ERROR : 0, 5
