Is strstr() supported in OpenAT?
My development environment is following.
Open AT Application Framework package (2.50.0.A1.201302131145)
OpenAT enviroment is very easy to use, helping you when missing brakets, parameters… other errors like type incompatibility will show you when building.
Every C standard library is very complete on SDK, try to write “strstr()” on SDK and will change of color, meaning that is available to use. Also you can use wm_strstr().
If not, make sure you know the library that contains your function or procedure, strstr() is a string.h library. And you can search all librarys in your SDK project tree -> Includes, search inside, when found read the library to see if function is available.
