I’ve installed a Sierra Wireless EM7565 (Qualcomm® Snapdragon™ X16 LTE-A) on my Ubuntu system and am trying to connect to the Telus network here in Canada. Unfortunately, the connection drops after a few hours.
Could you please confirm whether this modem is certified for use on the Telus network in Canada? Based on the documentation I found here, that appears to be the case. If it is certified, could you suggest steps to troubleshoot the connection issue?
Thank you @jyijyi I installed that version of the firmware it is SWI9X50C_01.07.02.00 6c91bc jenkins 2018/06/13 23:08:16, and the device is not working. This firmware is 12 years old.
So that is why I’m wondering if the device is still certified, and if so, which version of the firmware/drivers should I use.
@jyijyi I don’t see a recent firmware certified for Telus as well, so that is why I’m wondering if the device is still certified. Can you please clarify this point ?
Telus will not accept devices which are not certified on their network, so I’ll not be able to proceed regardless the firmware.
If it is certified, I can definitively test with the one you suggest.
