Hi, is there any funcion, call… enything to call an Event Handler to recognise the interruption pin?
Best Regards,
Henrique
Best Regards,
Henrique
Hi, a fellow from the forum told me:
Under OpenAT you enable the indication using AT+WIND=2559,
and then you will get a +WIND: 12 message when the interrupt
is triggered.
All right, the AT Commands Documentation really talk about it. But, how can I recognize the “+WIND: 12” message? I know we can send AT Commands with cmdCmdCreate… but how can I monitor the message?
Best Regards,
Henrique
Hi
I think that u shoould simply use adl_UnsoSubscribe("+WIND"…) for waiting the message.
But i’ve also a question
what type of interrupt you are interessting ?
It´s simple… suppose I have an external switch. I want to know exactly when it was pressed. I don´t want to check everytime it that pin is High or Low. Will this function tell me when it happens?
Best Regards,
Henrique
Hi thanks
Ok, because i’m in the same case but i use the adl GPIOs that call an event when there is a change in the PIN.
It really worked for me! But… do you know in what maximum frequency can it be used?
Best Regards,
Henrique
