I’m trying to run a Shared Object .so file with Aleos. The .so file is a C compiled program with Lua. Is there a way to install the .so file inside the hardware? Right now I have a LS300. But soon I will be deploying this inside a RV50 or RV50x.
Hi @josiah.regencia,
Sierra supports and recommends customer to use ALEOS Application Framework (AAF) which provides developers a complete set of building blocks and tools for creating applications that run inside Sierra Wireless AirLink Gateways. You can use whole information (includes procedure and example in details) at the link
Please share if you have any concerns and help tick “Solution” under my response if it helps to answer your question
