Hello
Please can u tel me if is there way to activate an unsolisited reponse to indicate that the SIM is full initalised.
Hello
Hello Malek,
You should be able to subscribe to +WIND indications to tell when the SIM reaches various states of rediness. Have a look under the +WIND command in the AT documentation and adl_UnSoSuscribe in the ADL documentation for more inforamtion on how to activate hooks and interpret the different WIND indications.
Kind regards,
Mike
If you use the ADL, then the +wind is initialised to the invariable decimal value ‘511’ (0x1FF) which means that the first 9 indications levels (bit 0 to bit 8) are set. Its not recommended to change this value.
If you (as [color=blue]MikeBean wrote) subscribe to the ‘+WIND:4’ unsolicited result:
adl_atUnSoSubscribe("+WIND: 4", (adl_atUnSoHandler_t) atUnSoResponse_PlusWIND4_Handler);
Then you’ll know when the unit is properly initialised to receive all AT-commands (SIM is fully initialised)
The callback routine to “catch” the unsolited result could look something like:
bool atUnSoResponse_PlusWIND4_Handler(adl_atUnsolicited_t * response)
TRACE (( 1, "atUnSoResponse_PlusWIND4_Handler" ));
return FALSE; // do not send to external application
You can in the same way subscribe to any other +WIND indication.
However, some needs to be activated with +WFM command.
Good Luck
/Snoooze
The best way consist in subscribing to SIM events with adl_Simsubscribe and wait for the ADL_SIM_EVENT_FULL_INIT.
See also adl_SIM.h for other SIM events.
Remember that it is highly recommended to wait to the full init, before issuing any GPRS action
Cheers
