Hi All,
I am trying to work on i2c bus of wavecom (Q24 Plus) with PCA9502 I/O expander ( nxp.com/acrobat_download/dat … 9502_3.pdf ) which has i2c/spi inerface.
Bus Enable always sucuss and bus write function always return -1 (BUS_MODE_UNKNOWN_TYPE)
Could any one help to find out the problem.
Thanks in advance.
Hi venkat,
Can you show the code? All i2c parameters config right?
ttt
Hi trthaithong,
I here by post my code as on your request.
void iic_Init( u8 id )
adl_atSendResponse(ADL_AT_UNS,"\r\n I'm in iic_Init\r\n");
/* i2c bus initialization */
// slave address 0x92
iic_BusHandle = adl_busSubscribe( ADL_BUS_TYPE_I2C_HARD|0x49, ADL_BUS_I2C_HARD_CLK_STD );
if( iic_BusHandle == ADL_RET_ERR_PARAM )
adl_atSendResponse(ADL_AT_UNS,"\r\n ERROR : ONE OF THE PARAMETER HAS INCORRECT VALUE \r\n" );
else if( iic_BusHandle == ADL_RET_ERR_ALREADY_SUBSCRIBED )
adl_atSendResponse(ADL_AT_UNS,"\r\n ERROR : IIC BUS ALREADY SUBSCRIBED \r\n" );
else if( iic_BusHandle >= 0 )
adl_atSendResponse(ADL_AT_UNS,"\r\n IIC BUS ENABLE SUCCESS\r\n" );
pca_Config( 1 );
else
adl_atSendResponse(ADL_AT_UNS,"\r\n IIC BUS ENABLE FAIL\r\n" );
void pca_Config( u8 id )
s8 iic_BusWrHandle;
char tempBuf[100];
// IOControl register address 0x0E
iic_BusWrHandle = adl_busWrite( (u8) iic_BusHandle, (adl_busAccess_t *) NULL, (u32) Data_Len, (void *) 0x07 );
// iic_BusWrHandle = adl_busWrite( (u8) iic_BusHandle, (adl_busAccess_t *) NULL, (u32) Data_Len, (void *) 0x0E );
if( iic_BusWrHandle == ADL_RET_ERR_UNKNOWN_HDL )
adl_atSendResponse(ADL_AT_UNS,"\r\n ERROR : IIC HANDLE PROVIDED AS UNKNOWN \r\n");
else if( iic_BusWrHandle == ADL_RET_ERR_PARAM )
adl_atSendResponse(ADL_AT_UNS,"\r\n ERROE : PARAMETER HAS INCORRECT VALUE \r\n");
else if( iic_BusWrHandle == OK )
adl_atSendResponse(ADL_AT_UNS,"\r\n SUCCESS : IIC BUS WRITE SUCCESS \r\n");
else
sprintf( tempBuf, "\r\n ERROR NUMBER : %d \r\n",iic_BusWrHandle );
adl_atSendResponse(ADL_AT_UNS,"\r\n ERROR : IIC BUS WRITE UNKNOWN ERROR \r\n");
adl_atSendResponse(ADL_AT_UNS,tempBuf);
For above code, i had the messages as below
I’m in iic_Init
ERROR NUMBER : -1
Please let me know any problem with my config code…
Thanks & regards
venkat
June 4, 2008, 10:04am
5
Hi trthaithong,
Currently i am using open AT OS v03.12 and open AT software tool v03.13.
I don’t know weather my OPEN AT version supporting i2c hard bus or not?
Which Open AT version support i2c hard bus?
Thanks&Regards,
venkat
Hi venkat,
You are already dev on the OS have i2c hard (OS v3.12). It is because of another reason.
ttt
Hi trthaithong,
Thanks for ur reply.
I have tested my hardware by use of scope. There SDA and SCL lines seems always
high. There no pluses observed!!!
Also adl_busSubscribe() function always success, i mean if i laod the slave address as 0x01,0x02… its success. How?
I am excepting a document about i2c bus of wavecom.
Could you please help to find out this problem.
Thanks & Regards,
Venkat
Madouc
September 8, 2008, 3:34pm
8
I suppose BusSubscribe only allocates the memory and initialises it with the provided settings.
bus_write/read commands (and their variations) are the only commands that actually output to the bus.
The only way busSubscribe would fail would be if it can’t allocate the resources it needs.
